![]() Join Date: May 2005
88front crossmember to 69
Will a 88 3/4 ton chevy front crossmember bolt right on to a 69 3/4 ton frame. thank
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: 88front crossmember to 69
IF it is the 73-87 bodystyle, yes.
If it is the '88-up with an IFS suspension, No. The control arms are bolted to the frame rails on those. There isn't an actual "crossmember" for the '88-up trucks like on the 60-87's
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
If it is a crewcab of suburban, it should. If it is a regular truck, no.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
what is the newest year that will is it 86?
The newest that will is the 1991 Suburban or Crew Cab if you want 3/4T. It HAS to be the same square bodystyle as the 73-87.
