Old 07-19-2002, 11:56 PM   #1
perrosinpata@aol.com
perrosinpata@aol.com's Avatar
Talking Its moving now to lower it
I bought lowering spindles that use 73 ball joints and i would like to install disc brakes. Now what.
perrosinpata@aol.com is offline   Reply With Quote
Old 07-20-2002, 08:17 AM   #2
GMCPaul
Thumbs up
Well I just happen to have the perfect kit for you. Both our 5 & 6 lug disc kits are designed to work with all 71-87 2wd truck spindles, and all 71-91 Blazer, Jimmy & Suburban 2wd spindels that originally used 1 1/4" rotors.
6-Lug Front Disc Brake Kit, Includes for both sides all needed Inner&outer wheel bearings, new grease seals, dust caps, Calipers, Brake hoses, Pads, 12" 6 Lug Rotors, spindle nuts, requires the use of 1971-87 spindles or our standard or drop spindles. Will not work with stock 63-70 spindles. 2 wheel drive only. Will not work with some stock drum brake rims.$219.95
or
5-Lug Front Disc Brake Kit, Includes for both sides all needed Inner&outer wheel bearings, new grease seals, dust caps, Calipers, Brake hoses, Pads, 2-12" 5 Lug Rotors with hubs, spindle nuts & cotter pins, requires the use of 1971 -87 spindles or our standard or drop spindles. Will not work with stock 63-70 spindles. Perfect kit to replace all those used front brake & bearing parts with new. 2 Wheel drive only. Will not work with some stock drum brake rims.$209.95
Both kits are designed to replace all brake wheel related parts with all new parts. You will find them at the following link
http://www.gmcpauls.com/Brakes&Steering.htm
GMCPaul
GMCPaul is offline   Reply With Quote
