02-08-2006, 07:58 PM | #1 |
72 LONGHORN OWNER
One Blinker working One not????
Any ideas left blinker and hazard working,right blinker and right hazard not working.Replaced cluster bulbs,looks like fuses are ok,and flasher is working.All outer lights on and working.???Any suggestions would be appreciated...
72-SUPER CHEYENNE/20 LONGHORN 70-C/30 DUALLY |
02-08-2006, 08:12 PM | #2 |
Re: One Blinker working One not????
remove your right side lights clean sockets and replace bulbs with new ones
02-08-2006, 08:15 PM | #3 |
Check the Blinker Fluid?
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
02-08-2006, 08:24 PM | #4 |
its all about the +6 inches
oooooooo, you got SYNTHETIC blinker fluid... you went all out on yours huh?
02-08-2006, 09:55 PM | #5 |
That synthetic blinker fluid causes leaks!
Seriously, time to get out the test light and start doing some testing. I think the complete wiring harness was posted on the FAQ section, shouldnt be to hard to track the problem down.
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
02-08-2006, 10:26 PM | #6 | |
02-09-2006, 02:42 AM | #7 |
Unplug and plug back in the turn signal harness connector coming out of the steering column. Also check the contacts in the turn signal switch.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
02-09-2006, 03:01 AM | #8 |
Also check the PCB on the back of the dash cluster for burns.
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES 's 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape |
02-09-2006, 06:49 AM | #9 |
I Had The Same Problem And Found That Spraying The Connectors With Electrical Contact Cleaner,or Electric Motor Cleaner Got Mine Working. Its Works Wonders. Now If Its A Plug Or Connector I Spray It.
02-09-2006, 11:54 AM | #10 |
Questionable
I have the same problem with mine, but mine has something to do with the socket. The one that is not working is abnormally hard to push in and take out...If I leave the bulb a little loose in the socket, it works...otherwise, I get nothing (when it's in properly). I couldn't figure this one out. I'm ready to replace the whole dang blinker assembly at this point.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
06-15-2006, 10:05 AM | #11 |
72 fleetside longbed 350
I had this exact same problem and the day I was reading this post I brought my blinker relay thing with me to work to take to the local parts store so I could get a new one. Instead of buying the relay I got some wire harness cleaner. Went home unpluged all connections and bulbs and sprayed em down. It worked like a charm! Thanx guys!
