Old 02-08-2006, 08:36 PM   #1
griesel72
griesel72's Avatar
Help!! Fuel gauge no workie
My fuel gauge in my 69 k10 hasn't worked since i got it, and i'm tired of running out of gas. I wondered what i should check first to get it rolling again. It is stuck below the empty line. I have tried to unplug the power wire (from the fuse box), and it doesn't move at all. Would this mean the gauge itself is bad? Should i check the sending unit?
Thanks for any help
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 02-08-2006, 08:45 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Help!! Fuel gauge no workie
well this can be like a dog chasing his tail.
a new sender is only about 60.00
if it's the stock one .i would bet it's not doing very well.
check the wire that run's under the threshold to make sure it's not pinched
you might want to do a check on this wire with the meter
and new gas gauge can be gotten very cheap as well
good luck..mark
rage'nrat638 is offline   Reply With Quote
Old 02-08-2006, 09:13 PM   #3
cdowns
cdowns's Avatar
check to see if there is power at the plug that connects to the sending unit then you disconect your ground wire from the tank to cab clean it bright and shiney reinstall and see if that works// if nothing there then pull the sending unit and see if it has a float attached to it or if the float is there and filled with gas
Old 02-08-2006, 09:15 PM   #4
domino52761
domino52761's Avatar
take wire that goes to the sending unit and ground it. Best why is to run a long wire form battery ground and touch it to the sending unit wire . If the gauge go's to full bad gound on senging unit . Or bad sender . I would try ground the senging unit . first.If that don't do it find the wire that go to the sending unit form the gauge on the back of the gauge and use the ground wire to gruond that on the back of the gauge .If it goes to full the wire form the gauge to the sending unit is bad .if it says on e the gauge is bad just my two cents
russ
65 short box fleet side
94 s-10 blazer
88 chevy bretta gt
my sons a train nut
domino52761 is offline   Reply With Quote
Old 02-08-2006, 09:20 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
ground wire from tank to cab?
There's a few things that it could be, but most likely, that brown wire you unplugged, is cut somewhere.
Slide the seat forward, reach back there and disconnect the brown wire from the tank/sending unit.
Turn on the ignition switch, see if the guage moves. It shouldn't. (the guage is in the unplugged wire position right now)
Now, ground that wire. Touch it to the tank, a bolt that holds the tank...what ever. The guage should run clear over to the full, or even beyond. I'm betting that it won't move.
If it doesn't move, do a continuity test on said brown wire. It is the same one you unplugged from the vuse box.
If there is no continuity, then you've found the problem. The wire is broke.
Old 02-08-2006, 09:41 PM   #6
68 Stepside
huh?
68 Stepside's Avatar
From what I've experienced on GMs, if the ground wire is not making connection, the gauge will read way over full... So, I'm guessing it's either a problem with the brown sender wire, or the sender itself. Trace the wire, check it, and see what you've got. Keep us posted.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 02-09-2006, 02:36 AM   #7
69TowRig
Well he said he unplugged it from the fuse block and the gauge is still below empty, so that rules out the entire wiring back to the sender for now. It should peg full like that.
Get up under the dash, unplug, clean and dielectric grease the dash harness connector, and plug it back in first.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 02-09-2006, 10:58 AM   #8
Premium72
Premium72's Avatar
sounds like yer wire...just run a new one. if it stayson emytp when the new wires on but moves when the wires off(after you replace it) check your float also. i had one go bad on me before. good luck. w.
Premium72 is offline   Reply With Quote
Old 02-09-2006, 11:22 AM   #9
RicksTrucks
RicksTrucks's Avatar
If it is the sending unit, you can find them cheaper. The last couple that I bought I only paid $39 each.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
