Dash lights not working!
My dash lights seem to be on the fritz. Sometimes they'll work, sometimes they won't. I know it's not the fuse. I just replaced the light switch. What else could it be? Somebody help. This is kind-of aggravating.
Re: Dash lights not working!
the plug going into the back of the dash
#3 | |
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
YES_____NO
![]() Join Date: Jul 1999
Or it could be a bad ground.
![]() People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
#5 | |
Lurky lurky
First make sure the dimmer on the headlight switch isn't turned off (all the way to the left)
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES ![]() 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape |
#7 | |||
Union Electrician
Third for a grounding issue, in all the dashes I have restored 99.9% of the time if there was an issue with the dash lights it has been a grounding problem. Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
C10 Club Tennessee
Now that I'm an expert on this
![]() ![]() Just make sure that the black wire from the plug(should have U-Clip) in grounded. The only other thing would be the printed circuit board. Good luck Matt
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
Thanks guys. I'll check both.
