02-09-2006, 02:56 AM | #1 |
lowering a 4x4?
Is it possible to lower a full size 88 Blazer 4x4? I just found a decent deal on one and I'd like to turn it into a Typhoon style street performance vehicle with an aggressive/low stance and probably 18” rims. What type of issues would I run into doing it?
Evan B. |
02-09-2006, 01:36 PM | #2 |
BLAZERHOLIC
Re: lowering a 4x4?
Hmm your steering I dont think would like the angles but I dont know that for sure. You wouldnt have to much clearance between the front axle and the front crossmember. You could have the front springs de-arched and put a drop shackle and hanger in the back to lower it a bit but I think front axle clearance will be an issue. You could use one of the offroad design front crossmembers that tuck up higher. Try it and tell us if it worked or not. Why not just convert it to 2wd?
02-09-2006, 03:44 PM | #3 |
www.73-87chevytrucks.com
Re: lowering a 4x4?
Not if it is a solid axle 4x4, which it is.
Issues would begin at the front leafs/steering and be compounded from there.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
02-09-2006, 05:26 PM | #4 | |
Re: lowering a 4x4?
Evan B. |
02-09-2006, 09:46 PM | #5 | |
Happy to be here
Re: lowering a 4x4?
02-09-2006, 10:19 PM | #6 |
Re: lowering a 4x4?
If you convert it, you don't have to go far for info. There is a HUGE post on here of someone that swapped both ways on 2 trucks. It WON'T be AWD though. Only way to do that is section the front of a 88-up 4x4 and put it under there.
02-09-2006, 10:38 PM | #7 | |
Re: lowering a 4x4?
Evan B. |
02-09-2006, 11:25 PM | #8 |
Re: lowering a 4x4?
I think you are talking about one thing and I am talking about another.
I am saying that if you put a 73-91 2WD front crossmember under it, it WON'T be AWD or 4x4 becuase a 2WD crossmember doesn't have the provision for a front driveshaft. Can you leave a 88 4x4 in 4Hi all the time, it wasn't designed that way. 4Hi is for off road conditions. AWD is a completely different Transfer case than what a 4x4 has. It is ALWAYS in AWD mode and can't be shifted.
02-09-2006, 11:45 PM | #9 |
Re: lowering a 4x4?
Oh ok. I get what you meant. -It's not possible to combine the best of both worlds.
Evan B. |
02-10-2006, 02:37 PM | #10 |
Slots go on anything!
Re: lowering a 4x4?
would it be possible to adapt the transfer case and front suspension from an AWD Astro? That would be pretty trick.
1974 Jimmy- 5.3/4L80e/NP241 |
02-10-2006, 11:07 PM | #11 |
MY EX DRIVES A BROOM
Re: lowering a 4x4?
if you want to do the 2wd conversion here is the post: http://67-72chevytrucks.com/vboard/s...d.php?t=168231 .....i would be happy to answer any questions you may have
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
