67 small back window
This may sound crazy, I like the small back windows of the 67 trucks. I have a 68 gmc with a large slider, If I got my hands on the back panel of a 67 with the small window and trimed it just right, I am thinking that I could just fit into the large window opening and weld/finish it off. Has anyone ever done this? How did it go? I really do not want to mess with swapping cab. Thanks for your help!
Re: 67 small back window
I like the small windows too... Let us know how this turns out.
Small windows rock! I've heard some guys on here explain how much of a pain they are to drive because of the limited visibility, especially in todays traffic, but that's why most of these trucks came factory with LARGE rear view mirrors. If you're really good at welding body panels it shouldn't be too difficult. Good luck!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Young truck fanatic
Maybe someone would just trade your cab for a 67 small window...two cabs saved everyones happy...Come on somebody has got to be somewhat close and up for a trade right?
Just a Thought -Jake
'67 Chevy Longstep 2wd 350 w/4spd manual Muncie M21. My first project. **Proud to be Valley Trash** |
![]() Join Date: Jan 2005
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
I reallydon't want to do the cab thing, I also dont want to trash a good cab. I also need a windshied for my 68 gmc, Maybe if rickstrucks cab doesn't sell???? I can get the windshield and just the back panel with glass shipped up??? Thats scary to ship glass but I guess it happens all the time! Keep me posted.
I`ve wondered the same thing.The flanges are there.It needs to be built out,it`s too deep as it is.I was thinking some day I`d try this:Gut out the back panel are on a`67(trashed,of course)cab,mark the large window opening on it,bend a 90deg. along that outline with the flange(bend)being the depth of the gasket flange,ang mig it/smooth it.Maybe weld reinforcement to the inside of the flat area on the`67 panel,1)to help against distortion and 2)to support what you put on the inside to flush the inner panel.
Active Member
I'm not sure how far you are from MN, but if you want I have a cab that would be perfect for this application. Let me know,
Thanks, Paul
'67 Chevy LWB (Running) '67 Chevy LWB (Not Running) '70 Chevy LWB (In Pieces) '72 Chevy LWB (In Pieces) |
Paul, do you mean the entire cab or the back panel itself with window?? Any Pics?? Thanks.
i did a cab swap to a small window. took a good while. lots of work!
Active Member
The entire cab that you could cut. Check your PM
