Old 02-10-2006, 11:17 AM   #1
jcfoote60
Active Member
jcfoote60's Avatar
Electric Fuel Pumps
Guys, on my 72 SWB I removed the gas tank behind the seat and installed a Blazer tank between the frame rails instead. I kept my stock fuel pump, however I have noticed when my truck sits overnight and I try to start it the next morning I have pump the heck out of the throttle before I get gas in the carb to start it. Also I have had two occasions this week where I will be just cruising down the road and all of a sudden the motor just feels like it is falling on it's face then kicks back in again. I am thinking I may have a fuel pump going out. Have any of you seen this problem and also what experiences have you had installing an electric fuel pump? Any recommendations as to which pump to get?
JC
jcfoote60 is offline   Reply With Quote
Old 02-10-2006, 01:32 PM   #2
bwright
Re: Electric Fuel Pumps
I had a holley blue on my S10...it worked fine:
http://store.summitracing.com/defaul...=egnsearch.asp
bwright is offline   Reply With Quote
Old 02-10-2006, 01:55 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
I'm having the same problem in my Burb with an electric pump. It's a cheapo so I'm replacing it with something better (probably the Holley red). Don't scrimp on quality here
Frizzle Fry is offline   Reply With Quote
Old 02-10-2006, 02:03 PM   #4
cdowns
cdowns's Avatar
i'd say first check your fuel filters to see if they're clogged next i'd check if you have rubber fuel lines if they're collapsing or crimped, if you have lengths of rubber lines over a foot in length i'd suggest for durability and safety replacing with metal lines// personally i'd stick with the ultra reliable mechanical fuel pump
Old 02-12-2006, 03:41 PM   #5
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I'm using the Delco EP12s electric fuel pump on BB no problems , GM part # 6472381
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
