1969 Custom 30 wrecker
I'm very confused. I ordered new rear brake drums from the Autozone.com website for my truck and they just arrived. Problem is, they don't look like the right ones to me. ?
I have a 1971 C20 with what I believe is an Eaton rear. (it has the large salad bowl center and the bolts are on the front side) On the website, they have 2 possibilities, one with a Dana rear and one without. I clicked the one without and ordered them. (see pics below) The ones shown are 11 5/16" X 2 3/4" I haven't had my drums off for a few years (truck is off the road) but when I did have them off last, I had to remove the center hub and pull the axle to get the drums off. The ones below look like that wouldn't need to be done. Questions are; 1) Do I have an Eaton rear as I described above? 2) Are the drums in the pics correct? If not, what are they correct for? Thanks in advance for any help... Bob
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
1968 C20 Vortec Beast
Re: 3/4 ton brake drum confusion!
They are correct! You have to remove the hub from the drum. If I remember correctly the wheel studs are what hold them in place.
Ugly or not it still kicks a**! |
Thanks alot!
![]() Bob
Take out the axle. then use a special hub socket. either has 4 or six prongs that will go into the spindle nut. take spindle nut off the a washer, then another spindle nut. The whole heavey SOB should slide of the spindle now..
The just get a brass drift and a heavy hammer and pound out the lugs. You can reuse them if you don't mess them up. Then reverse process and all should be A OK....
Support The Board |
Yeah the wheel studs "pound" out very easily -- but be sure to take it in and have a shop with a press and PRESS on the new assembly together.
Last fall I POUNDED my studs into the drum and hub and let me emphasis the pounding part. The last 1/4" of the studs to get down tight are a bugger. Just take it in for the whole disassembly/reassembly. I wouldn't do it myself again without a press.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
Thanks guys, all good advice. I appreciate it.
Just a follow up...
Everything went real smooth and just as you guys told me. It was also the perfect time to justify buying a new tool for the garage.... A 12 ton shop press. ![]()
Back in the sticks
mmmm, new tool smell....
![]() Congrats! Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
