Old 02-10-2006, 09:30 PM   #1
MrGoodpliers
MrGoodpliers's Avatar
Rust prevention inside doors?
I'm the proud new owner of a very solid western suburban. I was wondering if anyone could give recommendations on what to do inside the doors to keep them from rusting in my wetter climate. I would prefer a simple application without having to dip or blast the doors. I'm thinking of Eastwood's corroless paint or por15. Any ideas or opinions?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-10-2006, 10:24 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Rust prevention inside doors?
ebfabman had a trick using a garden sprayer modified to spray something (I don't remember what) inside doors. Maybe drop him a pm?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-10-2006, 10:24 PM   #3
JAKES 68GMC
Aluminum slot wheels rule...
I dont know if this will help you, but on my truck the original owner drilled a hole on the inside of each door. Pop the plugs out an squirt oil, spray grease, whatever. Also did that for the bedsides, and my truck is pretty much rust free. Hope this helps.
JAKES 68GMC is offline   Reply With Quote
Old 02-13-2006, 12:29 AM   #4
4x4Poet
If you are disassembling the door innards, get in their with a wire wheel, wire tooth brushes, and whatever else will remove the rust. Then clean, dry, maybe convert the remaining rust with zinc phosphate & dry, and then paint or POR15. I prefer brushing on grey POR15 for the inside of the doors because it is a great barrier to moisture (moisture curing) and the grey color keeps a little light reflecting ability so the inside of the door is not dark as with black paint. Brushing gets in the crevices better. From what I've seen, GM did not paint the inside of the doors unless as overspray.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-13-2006, 01:16 AM   #5
jhow66
jhow66's Avatar
Just wash out the inside of doors and let dry. Use spray on undercoating in spray cans.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-13-2006, 10:23 PM   #6
wolfthing2000
I think the garden sprayer idea with an anti corrosion spray like Gibbs, Corrosion X, LPS 3 or such should work real well. I plan on painting inside with a rust encapsulator and then spraying down with the above mentioned.
A friend I work with at the helicopter repair station (both of us long term aviaton) said some manufacturers use linseed oil sprayed inside of box and round steel tube when used in aircraft for a corrosion inhibitor.It might be worth a try. Lindseed oil is not anywhere near 100 a gallon like some of the other "name" stuff out there.
Just some of my ideas for ya.
wolfthing2000 is offline   Reply With Quote
Old 02-13-2006, 10:29 PM   #7
wolfthing2000
On the same topic, I remember hearing some people spraying hot oil mixtures under trucks and back into body panels with supposed good results.
Might get a little messy around the carpets and such.
Old 02-13-2006, 10:46 PM   #8
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
When I had to replace my door bottoms, while it was wide open I blasted the inside of both doors. But if you are not doing that, I would clean it very good with wire brushes, 80 grit paper or anything else you can get in there.
Now, after I blasted mine and welded in the new door bottom I used an epoxy primer and used a small paint brush and brushed the entire inside of the door. The next product I used is called Gravitex. It's the stuff body shops use to spray rocker panels and other areas to protect the surface from gravel chips. It's thinner than undercoating and it dries rock hard. It comes in a 1 liter bottle and it can be applied with a special spray gun that the supplier sells. I bought a case of the stuff ( about 6 bottles) and they gave me the gun free. A case is about $75.00. The spray gun has a long tube that will allow you to get it in all corners of the door by going through the window opening, the latch openings and the holes in the inside face of the door. It really does a great job. Just make sure you do not block the drain holes in the bottom of the door.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 02-13-2006, 10:48 PM   #9
bucket
bucket's Avatar
i like to use waxoyl on my classics.
bucket is offline   Reply With Quote
Old 02-13-2006, 10:59 PM   #10
4x4Poet
Hmmm...
I've seen a few methods here I hadn't heard of before. I still like my method, but ...(pondering, pondering)
Old 02-14-2006, 01:12 PM   #11
wolfthing2000
I asked my friend about the lindseed oil thing again, and he said they were engine cradles for Cesna, chrome moly tubing weldments with an access hole for filling and draining the lindseed oil out and then the hole was plugged with a cokld swedged in barbed fitting.
This was an FAA requirement! The stuff must work.
Old 02-14-2006, 01:29 PM   #12
72MARIO
72MARIO's Avatar
Kwown or Rust Check. They are the best. Oil sprays avaible
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-14-2006, 10:21 PM   #13
jimfulco
I've heard of people spraying used motor oil inside the doors every year, but I've never tried it.
jimfulco is offline   Reply With Quote
Old 02-14-2006, 11:26 PM   #14
wolfthing2000
Some of these ideas actualy sound like they would work. I think the biggest problem with doors and most rust prone panels . ,, is the nature of design, the overlaps of steel an spot welds make for a hidden spot for moisture to collect and probably were void of paint from day 1. I personaly use the Ospho , Metal ready or such and let it drool down into all of the crevices. Then seal it up the best you can with an encapsulator.
Others probably have better ideas, I enjoy hearing them.
I am in the process of closing up repairs on a rocker panel and plan on leaving a hole to spray the lindseed oil into . I would love to encapsulate the inside but it would probably kill you to weld metal with this stuff on it.
Old 02-14-2006, 11:50 PM   #15
Gazoo
Gazoo's Avatar
I agree with several of the above. Remove all loose rust and then apply an oil based water repellent. Rust Check is the best I know - it will literally crawl into any crevice and keep moisture out of the most damaging spots while maintaining its liquidity. I would avoid any type of solidifying undercoating as many will actually create moisture pockets if not maintained regularily.
71 short fleetside
Gazoo is offline   Reply With Quote
Old 02-15-2006, 09:05 AM   #16
wolfthing2000
Rust check huh? I'll Google it. I haven't heard of this one yet.
Old 02-15-2006, 09:48 AM   #17
smokekiki
Mike
smokekiki's Avatar
I would stay away from the used motor oil.Who wants to smell that !
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-15-2006, 10:22 AM   #18
67ChevyRedneck
67ChevyRedneck's Avatar
Remove all the rust the best you can. I'm going to coat the inside of my doors with eastwood's rust encapsulator. My doors are brand new, but it should work well for you. Googe "eastwood rust encapsulator" and another product called "zero rust." They are both supposed to be really good.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-15-2006, 01:00 PM   #19
wolfthing2000
RUST bULLET
Old 02-15-2006, 01:24 PM   #20
bucket
bucket's Avatar
When i use waxoyl i warm it and mix 50/50 with clean motor oil. the oil helps the waxoyl creep into existing rust. the waxoyl stiffins slightly and creates a waxy barrier robbing rust of air and moisture (what it needs to survive). don't use used motor oil. it contains impurities which can promote rust (or so i've been told).
