Old 02-11-2006, 04:36 AM   #1
68 50th
68 50th's Avatar
Crank pulley/frame cross member clearance
Can anyone tell the approx clearance between crank pulley and front cross member?
I can't even get the fan belt out and something tells me it should be more clearance there.
The only thing I can think of is sagging motor mounts, but they do not really look that bad.
It is a 2wd 71 3/4-ton with 402 big block but it got the 72 style big block motor mounts.
Thanks.
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
Old 02-12-2006, 01:09 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Crank pulley/frame cross member clearance
Here's a picture of my 70 model that I swapped to big block. Lots and lots of clearance.
Old 02-12-2006, 01:21 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Seems to me like the big block is in the forward motor mount holes???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-12-2006, 02:56 PM   #4
Tx Firefighter
Yes sir, big blocks mount in forward holes. That's where mine are in the picture above.
Old 02-14-2006, 05:15 PM   #5
68 50th
68 50th's Avatar
Tx Firefighter: Thanks a lot for the pic.
I can see there should be a lot of clearance.
Maybe the cross member has been bent at some time on my truck.
I don't know how it should be shaped but it looks (from Tx pic) like it shouldn't be bowed very much if looking at it from one side or from above.
Can anyone tell if this looks right or wrong?
Mats..
Old 03-28-2015, 01:14 PM   #6
CC Rider
I have the same issue on my 67 c10. Did anyone have a root cause and fix for this ? I think I have a 454.
CC Rider is offline   Reply With Quote
