how strong are the factory rivets on the frame? is it worth my money to knock off all the rivets and replace with grade 8 bolts?
80 Chevy K10 350/350turbo 86 Chevy 1/2 ton shorty project truck 79 Chevy 1/2ton 350/350turbo not much to look at... ***Retired*** 97 Chevy C1500 4.3/5 speed.....daily driver |
River life......
Re: factory rivets
The only factory rivets that I have seen shear were due to a wreck.
Until Seventy Times Seven
Re: factory rivets
I believe the factory rivets are a better choice as a frame fastner than high-grade bolts. Aside from their strength as a fastner, rivets 'expand' to fill the hole of the attaching parts.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#4 | |
Re: factory rivets
- Greg |
Re: factory rivets
True, but rivits don't work loose and have part of them fall off, usally. If you were to also install some lockwashers, and tighten the crap out of them and check them everyonce in a while, and willing to go threw all the work to do it and make shure they stay tight, then go for grade 8 bolts. Otherwise keep the rivits.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
#6 | |
Re: factory rivets
Good point. Personally, I've never noticed any rust/movement stains indicating movement between the rivet(s) and the chassis. And, the ones I had to remove were still very tight. If rivets have to be replaced, I'd go with fine-thread, grade 10 bolts/thread locking nuts (if available) and thread locking compound. Use the largest bolt that will fit tightly into the hole. Since the holes are sometimes odd sizes, some may have to be reamed out to the next larger size. Then, be sure not to over torque. I know they supply rivet kits for the Model T and Model A. I wonder if it's possible to use replacement rivets using a bucking bar and a ball peen hammer with a hand-held rivet tool or an air hammer with a rivet attachment. I would guess that rivets may be cheaper than high-grade bolts/nuts, but I imagine the cost to install the rivets are probably more expensive since operators use large hydraulic presses that are suspended to press the rivets in place. Today, I wonder if that process is now fully automated. (Maybe, Jeff's GM video has a clip of a 73-87 chassis being assembled.)
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 02-12-2006 at 03:30 AM. |
Re: factory rivets
I wasn't trying to imply that all the factory rivots should be replaced with bolts just for the sake of replacing them. But, if you have a need to replace a part that was originally rivoted, or if you are completely stripping the frame rails down to paint them, then reassembling with bolts should be just as good if not better than the factory rivots.
When I stripped the front of my truck's frame I did find that some of the rivots were loose. The cross brace that is in front of the engine crossmember is one place. And a sway bar mounting bracket was another place. Also, I found significant amounts of rust behind the radiator core support mounting brackets. Seems like that is a good place for dirt to collect and trap moisture. And yes, I had to use a step drill bit to enlarge the rivot holes to the next standard bolt size. I used all grade 8 bolts with grade 8 flat washers on both sides, but I used ny-lock nuts which are grade 5. As for periodic maintenence to check the tightness of the bolts, I suggest you check them just as often as you check your engine crossmember and tranny crossmember bolts.
- Greg |
ureckmefixit2@cox.net
Re: factory rivets
When I replace rivits at the body shop I use 8 grade bolts and tack weld the nut to the bolt
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
Right turn Clyde
Re: factory rivets
But isn't there also the harder a bolt is the grater its change to just shear off? Kind of like a bolt extractor set, the taps are really strong but very brittle.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#10 | |
Re: factory rivets
454HO, how's your build-up coming along?
#11 | |
Re: factory rivets
- Greg |
Re: factory rivets
Factory rivets persay on class 8 trucks are called "huck" bolts. Pretty damn tuff...but require a expensive hydraulic gun and pump set up on a cart to install. I think a better bolt might be a flange bolt and nut...not sure on the grade but they are pretty tough. I have them holding my winch and bumper on my 79 K5...bit more pricey than a grade 8 bolt but they do the trick.
DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
