02-11-2006, 10:33 PM | #1 |
Pick'n up the pieces!
First exhaust system
02-12-2006, 06:01 AM | #2 |
Its Magically Delicious
Re: First exhaust system
did you make that yourself .. or was it a kit ??... looks good
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
02-12-2006, 07:37 AM | #3 |
Watch out for your cornhole !
Beautiful work there.
All I can offer is, normal exhaust clamps will crimp the pipe enough that it's not readily able to be taken apart later. If you decide to use clamps, use "band" type of clamps. They don't crimp the pipe like the "u-bolt" type does.
02-12-2006, 08:36 AM | #4 |
Looks great, I vote weld and then coat with a stainless high temp exhaust paint on the weld beads. My exhaust contains no clamps -- my hangers are also welded to the pipes. I did not run a crossover so that I can still drop eachside off the engine more easily if needed. Are those Flow Master 50's?
02-12-2006, 08:55 AM | #5 |
Real nice job! Can't believe this is your first exhaust system. Where did you get the bends and tubing and what gauge did you go with?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
02-12-2006, 09:01 AM | #6 |
I would reccomend the stainless band clamps. I tacked the pipe to the muffler in 2 spots just to help hold it from twisting. The band clamps do not have alot of holding strength the weld helps them out. I also welded te hangers to the pipeone less spot to start rusting. I used VHT flame proof silver paint.
I also did put in a H pipe each side can be droped seperatly thanks to a joint in the center using two 3/8" thick flanges with a copper gasket between them. Like a headder to collector connection only you have thick flanges on both sides to promote a leak free seal.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-12-2006, 09:51 AM | #7 |
i would recomend clamps seeing as i hate welding mufflers on (dont use the u bolts clamps though) because the muffler went out on my pos f-150 and the idoit that but it on welded it and when i muffler shop took it off they ended up having to replace the whole system 800 buxs geeeeezzzzzz Just.my $.02
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
02-12-2006, 10:34 AM | #8 |
The LuvShack Garage
Nice work
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-12-2006, 10:53 AM | #9 | |
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 Last edited by Chevrolet4x4s; 02-12-2006 at 10:54 AM. |
02-12-2006, 11:04 AM | #10 | |
The LuvShack Garage
Hmmmmmm, if that included cats that's cheap, my F-150 has 4
02-12-2006, 12:46 PM | #11 |
I can't see where they could justify an 800 dollar muffler job on an 87 model F150.
Even if the had to cut some of the pipe back to get to undamaged pipe, they should have been able to splice in a 1 foot section either side of the new muffler without getting that extreme.
02-12-2006, 03:54 PM | #12 |
Wow guys, that's the most response I've ever gotten! The mufflers are Delta 40's and all the pipe is 2.5 aluminized. This is a cheap way to go. It consist of three 4 ft straight pipes and 4 J bends. It is a lot of cutting and fitting though. All welded up with a Hobart 135 MIG. Tubing from Summit. Hope I covered questions. Thanks for the input on the clamps. Danny
02-12-2006, 07:58 PM | #13 |
68 C/10
Will you be running an under bed tank as shown in your avatar? If so how much room do you have between the tank and pipes. I like the way it comes though the cross member behind the rear dif.
By the way great job!!
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car |
02-12-2006, 08:36 PM | #14 |
Black 72 Chevy
IMO weld, unless you plan on taking it apart once in while. By the way, you did a good job.
A.P. |
02-12-2006, 08:49 PM | #15 |
Thanks polevault1977!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. Last edited by Sweet72; 02-12-2006 at 08:49 PM. |
02-12-2006, 10:35 PM | #16 |
Yes, I am running a No-limit aluminum tank. I had No Limit to shorten the tank about an inch and one half so I would have room for the exhaust pipes. It is a tight fit but I think it will work. I'll post pics when I get it all together.
02-12-2006, 10:54 PM | #17 |
68 C/10
Cool!!!
02-12-2006, 11:42 PM | #18 |
Village Idiot....
What about using header flanges welded to the mufflers and the exhaust pipes so you can take it apart and have it plated? We use this on all the exhaust systems we make so we can plate and it makes it easier to re-install.
02-13-2006, 09:54 PM | #19 |
Thanks for the input. Flanges are definitely a viable solution. Danny
