02-11-2006, 11:03 PM | #1 |
flame throwers
guys i wanna know how to put flame throwers in my exhaust please help me
02-11-2006, 11:06 PM | #2 |
Happy to be here
Re: flame throwers
02-11-2006, 11:12 PM | #3 | |
Son Of Gravel Man
Re: flame throwers
Whats the cheap way to do it with a spark plug?
Edit: I found it http://www.skepticfiles.org/new/054doc.htm Auto Exhaust Flame Thrower by The Jolly Roger For this one, all you need is a car, a sparkplug, ignition wire and a switch. Install the spark plug into the last four or five inches of the tailpipeby drilling a hole that the plug can screw into easily. Attach the wire (this is regular insulated wire) to one side of the switch and to the spark plug. The other side of the switch is attached to the positive terminal on the battery. With the car running, simply hit the switch and watch the flames fly!!! Again be careful that no one is behind you! I have seen some of these flames go 20 feet!!!
Daily driven 70 C10 longbed Its a work in progress Quote:
02-11-2006, 11:30 PM | #4 |
Re: flame throwers
do you use a manual choke to spit out some raw fuel
common sense isn't so common anymore |
02-11-2006, 11:50 PM | #5 |
Check out GMTrucks.org
Re: flame throwers
Yeah, the kit above kills your ignition so you send raw fuel out the exhaust. You have to have something to ignite. Just a spark plug is not going to work unless you are running really rich (which you don't want to do all the time).
02-12-2006, 12:47 AM | #6 |
Active Member
Re: flame throwers
this is a REALLY bad idea.... You have RAW gas washing down the cylinder walls, thus removing all oil and lubrication from the engine. Ive seen it first hand...if you want to ruin your engine, go for it, it will work, for awhile, then you;ll be putting in a new engine.
If you want flamethrowers, install a propane kit and plug in the tailpipe. My two cents J ________ Beeman Quick Cleaning Pellets 100Ct Last edited by Jayss109; 04-27-2011 at 11:34 PM. |
02-12-2006, 12:55 AM | #7 |
Re: flame throwers
well this is kinda right up my alley. be forewarned that small block chevys don't like this at all. you WILL kill your engine. flathead fords handle this very well,though.
02-12-2006, 02:05 AM | #8 |
Re: flame throwers
put a servo /w/ a needle at the end of it directally over ut tail pipe.....next to the needle, fill a bag of gas....OPERATE SERVO!!!
02-12-2006, 05:37 AM | #9 |
Re: flame throwers
A buddy of mine -- kind of an old school hot rod gearhead -- told me I could put a V8 distributor on my L6 and run two of the wires back to bungs welded in the tail pipes [yes it has dual exhaust], to get the flamethrower effect. I knew he was kidding because the V8 dizzy is too short on the shaft and too wide next to the block to actually fit. Also it wouldn't run right at 1-5-3-Miss-6-2-4-Miss.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-12-2006 at 05:40 AM. |
02-12-2006, 09:03 AM | #10 |
PROUD TO BE A MEMBER
Re: flame throwers
i am from the south and kinda slow ,but if I used the simple system , its saying a 12 volt battery can make a spark plug fire,i don't think so ,thats why we use a coil ,you put 12 volts in get 16,000 volts or more out . its the high voltage out that fires a plug . now in the olden days then motors blew 30/40 % of your fuel out the tail pipe when running ,put a constant firing spark plug on your tail pipe and bingo your a bad ass hehe even works on an old flat heads
PS this is really old school ---BTW the 200 dollar unit is nothing but a switch ,note you supply the coil and the plug ,don't confuse this with coil with your engine coil two different coils to sum up for my Yankee friends two wires from you battery to input on a coil --put a simple switch on one of the wires so you can turn your toy off and on .coil out put to the spark plug in tail pipe and bingo your a redneck like me, fire shooting trucks always gets the girls laffin |
02-12-2006, 03:34 PM | #11 |
Active Member
Re: flame throwers
Put this together for you, do I win the FAQ contest???
-Fred "The Great State of Florida" |
02-12-2006, 10:37 PM | #12 |
Re: flame throwers
I wanted to put a propane kit on my truck (I work for a propane company), the only problem with that is that I would probably forget that I tow trailers sometimes and torch the front end of the trailer.
02-13-2006, 02:51 PM | #13 |
Re: flame throwers
Here is the link to the kit that I installed on my CST. It works great.
http://www.hotrodsetc.net/orderspitfire.htm
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
02-13-2006, 08:26 PM | #14 |
PROJECT 7DEUCE
Re: flame throwers
Anyone have pics of this set-up in use on there ride?????
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-01-2007, 12:35 AM | #15 |
Re: flame throwers
08-01-2007, 02:08 AM | #16 |
Re: flame throwers
Jayss109 is correct when he tells you that the traditional way sends un-burnt fuel through the exhaust valves and out the manifolds. Because you have to run fairly rich It will cause the fuel to run past your piston rings and into the oil pan destroying the viscosity and eventually with enough use cause some serious damage.
What you get in an off the shelf kit is basically a 10.00 relay in a magic "sparker box", some o2 bungs, connectors, wire and if your lucky a coil and plug. How many would pay 100.00 pluse for that? The most effective way is to plumb the fuel line from the fuel pump using N.O.S valves then N.O.S nozzles about 8" from the spark plug. It will atomize the fuel and allow you to light up without killing the ignition and while going down the freeway. Its pricey but it works well and won't damage the motor. You can even use it on emmission controlled cars cause you introduce the fuel after the cats and o2 Sensors. Just my opinion
The puppy barks but the trucks roll along. |
