Old 07-20-2002, 04:53 PM   #1
dion
72 Cheyenne
dion's Avatar
How do you know when your torke converter is bad?
Ever since I had a new flywheel put in there's been a lot of noise coming from the converter or that area at least. All of the bolts are tight and everything seems in order. It still makes a quick screeching sort of a grind noise when I start it, obviously it's not engaging right but can the converter be bad as well?
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 07-20-2002, 06:54 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
You had the flywheel put in? If it were me, and it was put in (by a shop), I'd take it back, and make them remedy the noise, and the problems with the starter engaging. You're gonna eat the teeth right off of the flywheel if you keep running it with the starter shimmed incorrectly.
At any rate, what kind of noise does it emit? Is it a knocking/tapping type noise?
Good Luck, and ttt
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-20-2002, 06:55 PM   #3
Randy70C-10
Randy70C-10's Avatar
Was your torque converter in the tranny completely? (you should be able to move it back and forth about 1/2 inch) If it isn't, you can put things in a bind. Also, you didn't put the flexplate on backwards did you?
Randy70C-10 is offline   Reply With Quote
Old 07-20-2002, 06:58 PM   #4
bbs1965
Open Sundays 10 till 10
if converter isn't seated right it will kill front bump in a quick ass hurry. either wrong flywheel or starter is staying engaged.
bbs1965 is offline   Reply With Quote
Old 07-20-2002, 07:10 PM   #5
dion
72 Cheyenne
dion's Avatar
Yes, a tapping clicking type noise. After my rebuilt was installed it wouldn't start correctly so I took it back and they noticed that my old flywheel had broken teeth so they put a new one in, why they didn't put a new one in in the first place is beyond me since they put in a new starter, I had to take it back 3 times for this (and about 6 other times for other things) anyway, the last time I took it back he told me that noise was the oil pump and there was nothing he could do, yeah right!
Burnout
Idle
1972Cheyenne
1966/67Stouts
