07-20-2002, 05:17 PM | #1 |
NEED HELP with vent window handle
I had to replace the glass in my vent window, but can't get the old handle apart to put it in the new glass, how does it come apart?
Thanks Todd 72 4x4
Todd Davidson 1972 Chevrolet LWB 4x4 San Antonio, TX |
07-20-2002, 06:39 PM | #2 |
huh?
Well, I'm gonna bend over, and let my a$$ do the talking here, as I've never actually taken one apart.
But, There's just a small roll pin, at the base of the handle, near the glass. All you need to do is drive that out, if my memory serves me correctly. Then it should just pull apart. Good luck! TJ
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
07-20-2002, 11:53 PM | #3 |
GYRO GEARLOOSE
Good guess, then the rest comes apart like a nut and bolt.
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
07-20-2002, 11:55 PM | #4 |
its all about the +6 inches
Wow...neat trick, I wish my ass could give perfect instructions!
07-21-2002, 06:25 PM | #5 |
Thanks for the help, even if it did come from the other end
thanks again todd
07-22-2002, 10:19 PM | #6 |
Make sure the new vent window glass is same thickness as old glass. If it is thinner, the handlle will be slightly loose when you close the vent and it will not seal well. Happened to me .
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
