Old member
Serpentine Setup
OK,
My mechanic friend gave me a complete setup off a 4.3. It has all the pulleys,power steering,water pump,alternator,A/C compressor and brackets. I have a 1986 camero 305 TPI motor in it and want to know is it a direct bolt in. I know I have to change the water pump,alternator and compressor. I took everything off the motor myself I got all the bolts nuts everything off of it. Will this setup work and what to look for while doing the install. More pictures on my website at bottom of page. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Mar 2001
Re: Serpentine Setup
Was the 4.3L a TBI engine? If so, is the AC pump on the same side?
I have ran into issues with the AC Bracket for the R4 compressor may be an issues with the TPI engine instake manifold hitting near the top. Should be able to remove the fitting on the back of your existing power steering pump and insert it into the new PS pump and use your existing hose. That is if you even need to do this. Other thing to note, beside converting the water pump over to a reverse rotation for serpentine, is your existing the same type, ie, long? You may need to replace your fan and fanclutch. GM sells a heavyduty version and get fan for an s-10 or full size 5.7L, between the two, I prefer the S10 fan. You will also need a bigblock fan shroud to fit the larger dia fan.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I did a serpentine swap from a 4.3 V6 onto a 350. Everything was pretty much bolt on.
First, the support rods that came off the front brackets and went back to the intake manifold bolts on the V6 didn't line up with the bolts on the V8. I went to the dealer and bought the two V8 support rods and replaced the V6 ones. Problem solved. Second, the 4.3 had a real thin harmonic balancer, the V8 had a normal thick one. The crank pulley off the V6 was much deeper to compensate for the thinness of the balancer. I had to buy a 350 lower pulley off a generic 88-94 full size truck with V8 and serpentine. It was much shallower because of the V8's normal thick balancer. Everything else was bolt on deal. Keep in mind though, these were both TBI engines that I dealt with. I don't know how a TPI setup would complicate things.
faster, faster, faster
OK, I don't mean to hijack, but I imagine this question could benefit both Andy and myself. When you say, "reverse rotation water pump", what exactly do you mean? A stock WP for these trucks turns clockwise, while a WP from a serpentine system turns counter clockwise. My question is, can a pump for the year vehicle the serp. system came from be used? Don't they both flow the same direction, just turn opposite ones?
I'm going to Law School, wanna debate? It's good practice. Last edited by my new 72; 02-12-2006 at 04:21 PM. |
#5 | |
Since the serpentine drives the water pump off of the back of the belt, it turns the oppsite direction as a normal pump does. GM just made a backwards impeller, so the water flows the same, but the pump turns backwards. You just ask for a water pump for the year of serpentine brackets you're using. It will bolt right onto your earlier engine without mods.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 02-12-2006 at 04:45 PM. |
Old member
Thanks guy's that is what I needed to know. I'll take pictures as I procced.
excellent. That is what I was thinking, but I just wanted to make sure before I went and got the wrong thing.
I'm going to Law School, wanna debate? It's good practice. |
Old member
I talked with my friend and he has the 350 balancer I need for it. Will my alternator work with swaping the pulley out on it? If so all I have to do is buy the A/C compressor and bolt everything up. I may have to redo my upper raditor hose too.
You should be able to swap pulleys on the alternator and use it without further issue. You made mention about the upper hose, you may also find you need to change the lower hose. Do you have the part numbers for the two main brackets..if so, post them and I will compare them to the two sets I recently used in a swap.
Old member
I will look at them tonight and post them. Thanks Andy
Old member
Here are the #'s off the two brackets. This is the alternato bracket drivers side #10118701
A/C bracket passenger side # 10129515
Hmm
