Old 02-12-2006, 02:42 PM   #1
NitroMike
Active Member
NitroMike's Avatar
153 vs. 168 flywheels
Hey guys, I believe that 250 inch L6 use 168 tooth flywheels. Just bought a high performance one on Ebay that is 153 tooth. Is this just an easy swap of starters to make it work? Any other issues to be aware of? Did 6 cylinders use both 153 or 168 at different times?
Thanks!!
The older I get, the faster I was!!
NitroMike is offline   Reply With Quote
Old 02-12-2006, 02:45 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 153 vs. 168 flywheels
I've swapped both large and small flywheels onto my sixes over the years.
The flywheel is bolt on.
All you have to do is put a different nosecone onto your existing starter if you're using a block mounted starter.
Old 02-12-2006, 03:05 PM   #3
70GMCer
70GMCer's Avatar
I've did the same thing with the V8s
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 02-12-2006, 03:09 PM   #4
Tx Firefighter
I swapped my 292 from standard trans to auto trans a few weeks ago. I just used a flywheel I had laying around, which worked out as a 153 toother. I just swapped the old standard trans type of nosecone off the starter to a straight across 153 tooth style auto nosecone. It was like a 5 minute swap on the starter nosecone.
Old 02-12-2006, 06:04 PM   #5
NitroMike
Active Member
NitroMike's Avatar
Thanks Tx. I'd take your 292 if I was a little closer. My truck came from Dallas. It hates the East. The body is rusting just sitting inside my garage!
