02-12-2006, 06:36 PM | #1 |
Back Spacing calculation
I am not 100% sure and want to be before I order my new rear rims, There will be wheel tubs so inner dimensions not an issue. Frame width is 34"
My outside measurement inbetween the rear fenders (stepside) is 73.25" Axle width drum to drum is just under 55" Rims will be 12" wide Tires are 15" wide 73.25 - 2.25 (rounded off) space btween tire & fender = 71" (1 1/8 per side) 71" - 55" = 16 / 2= 8 would mean a 4" BS 4" + 1.5 = 5.5 BS (1.5 is for tire over hang) Anyone else come up with anything ??
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
02-12-2006, 08:15 PM | #2 |
67-72 parts collector,…
Re: Back Spacing calculation
Just remember that a production 12" rim will ACTUALLY measure 13" from the outside edges of the rim. The 12" measurement is the tire bead surface. I like to take a "know rim",...(like a 15x8 truck ralley) and use it to measure off of. Mount it under the truck, (without a tire), and add or subtract inches to put the wheel where you want it. I hope this helps.
02-12-2006, 09:48 PM | #3 |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-12-2006, 10:54 PM | #4 |
Hollister Road Co.
http://www.earlywheel.com/choosing.html has a simple way to find out what you need down on the bottom of the page
