Old 02-13-2006, 12:38 AM   #1
muddpile
muddpile's Avatar
Drum Brake Pad Replacement?
I think you call drum brake pads shoes or something, but I can't really remember. My question is, how thick is a good one vs. a worn one? Mine have about 1/8" - 3/16" of material on them still, but I have no idea how much they are actually supposed to have. Also, is it a tough job to replace and set them?
muddpile is offline   Reply With Quote
Old 02-13-2006, 01:19 AM   #2
jhow66
jhow66's Avatar
Re: Drum Brake Pad Replacement?
Time to change them. Not hard to do.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-13-2006, 02:47 AM   #3
Rollie396
someday it will be done!
Rollie396's Avatar
not real difficult but if you've never done them before it can be interesting.
I'd suggest either taking a pic of the set up before taking apart.That or keep the otherside together for referance.It's amazing how fast a memory fades once something is apart.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 02-13-2006, 03:34 AM   #4
Smallz72project
Smallz72project's Avatar
The first time I did drum brakes....it was a mess and I had to go buy book on the truck so I had a picture to know how to put it back together. But now I work at Les Schwab doing brakes all day. They are pretty easy to do actually, although if you go out and spend some money to get some brake tools it makes life ALOT easier and cuts time by at least half. the major tools that are helpful are the spring pliers that have a curved hook on one side and straight hook on the other and the ends are designed to help remove and install the return springs, one looks like a curved claw and the other is a dish with a nub on the side. when you get the new shoes, look at them and take note for future reference in determining if they should be replaced, if its a bonded shoe..it should have a straight line in the shape of a V going across the shoe and when the V is no longer there its time to replace, and if its a riveted shoe, change them if its close to or at the rivets. When you are putting them together, remember that there are two different shoes in most cases, one is called a Leading and the other Trailing. Take the star adjuster apart and clean it up and put Anti-seize on any moving parts. Make life easy on yourself and completely adjust the star adjuster down before assembly, will make putting the drum on alot easier. Adjust it out until you just feel slight drag when the drum is rotated. Hope this helps, have any other ?'s just ask, oh and I HIGHLY recommend having the drums turned. Happy Travels.
Smallz72project is offline   Reply With Quote
Old 02-13-2006, 07:19 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The thickness issue will depend on whether the shoes are riveted or bonded. What I mean is whether the lining material has holes and rivets holding it to the steel part of the shoe, or whether they are hole less and glued to the metal part.
If they are riveted, look in the rivet holes and judge how far remains till the rivets would start to rub.
If it's glued, just measure the lining thickness.
Anyway, if it is 3/16", that is actually a lot of life left.
Old 02-13-2006, 12:19 PM   #6
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Go for it!! It is intimidating at first when you take the drums off since there is a lot of parts, but if you take your time you should be ok. I did mine for the first time about 4 months ago and it was a little frustrating but after I got the first one done the second went quite smoothly. I would recommend buying a Haynes manual or something similar to help you. It has detailed pics and drawings that you can refer to if you get stumped. I'd also recommend going ahead and buying a new spring & parts kit if you're going to replace the shoes. The kit should be about $10 and you'll need 2 of them. Then you won't ever have to replace that stuff again.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 02-13-2006, 02:52 PM   #7
crazyred
yeeha
crazyred's Avatar
just do one side at a time so you have somthing to refer to on the other side. Its a lot of running back and forth but it's what saved me the first time i did mine!!! its i good idea to take your drums to a shop and have them turned so there nice and round .... just my two cents
1969 GMC 910 97% rust free
2002 olds Alero
1986 New Yorker 4dr ... the new DD...My POS car... dude its got a turbo!!!
Don't drink and drive, you might spill something!!!
Daryl Kuchmak
crazyred is offline   Reply With Quote
Old 02-13-2006, 02:59 PM   #8
Joe67
67 is sold
Excellent advice right there
Having the proper tools is key as well
Good Luck!
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 02-14-2006, 12:40 AM   #9
muddpile
muddpile's Avatar
The pads are bonded and not riveted. There are no rivet holes that I can see. At 1/8 to 3/16", should I still consider a rebuild? Also, the diff is from an early 80's suburban (not sure what year) so what would I need to tell the parts guys when getting parts?
Old 02-14-2006, 06:07 AM   #10
jhow66
jhow66's Avatar
Yes if they are down to 1/8". Tell him you want brake shoes for a early 80's 'burb'.
Old 02-14-2006, 10:18 PM   #11
jimfulco
Don't breathe the dust.
jimfulco is offline   Reply With Quote
Old 02-15-2006, 12:37 AM   #12
LMN8UR
LMN8UR's Avatar
Another thought, take one side with you to the parts store. Auto-Zone never gives me the right stuff the first time.
Clean everything GOOD! Make certain the adjusters work. If you are brave enough to take both sides apart at the same time, Don't put the parts in one pile! ! Don't ask me how long it took me to figure out the adjusters are different! I Said Don't ASK! !
Good Luck, and may the Raybestos Gods be with you!
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
