02-13-2006, 09:29 AM | #1 |
what can I swap?
Well, i came across an 89 3/4t 4x4 down the road in need of serious body repair......thought it might make a good donor vehicle. I was thinking I could pull the front axle to get myself some disc brakes, the hydraulic clutch would be VERY nice, possibly pull the bucket seats. It's a manual trans, but I like my column shifter, so I likely won't swap that out. Hoping that the rear has a locker in it that I can pull, will rims fit on a 70?
Anything else that I could scavange to make it worth the time and effort? I figured once I was done, I would part out the rest of the rig. Haven't looked at it yet, but in 89, would that be a 4 or 5spd? Thanks!
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
02-13-2006, 11:04 AM | #2 |
Re: what can I swap?
Hmm that 89 is it a solid front axle still....if yes, then yes it could be used on the older style trucks..if solid axle it would be a GM 10 bolt front. I believe it would still be a 4 speed in the 89.
Is this an 8 bolt rimmed 3/4 ton or a 6 bolt rimmed 3/4 ton, either should fit anyway to the bolt pattern being matched in you earlier years truck.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
02-13-2006, 12:02 PM | #3 |
Unless it's a crew cab, it's IFS front.
Should have a 14B rear. Should be a five speed, if it's a manual. Motor should be a TBI350. |
02-13-2006, 10:01 PM | #4 |
If it is a crewcab(old body style) it will have a 4spd.The only regular cabs with solid front axles in`88 &`89 were old body style 1 tons.
