02-13-2006, 03:59 PM | #1 |
Best way to test electrical system with no engine
Recently bought a new project and I want to see what I've gotten myself into. I'd like to check out the electrical system to see what is working. It does not have an engine in it. Can anyone tell me the best way to hook up a battery to get juice to lights, etc.?
Any info is appreciated. Thanks. |
02-13-2006, 04:11 PM | #2 |
Re: Best way to test electrical system with no engine
Your pos battery cable should have a fusible link connected to a junction block on the inner fender. That is your main power to the fuse panel. Just find somewhere to ground the neg cable.
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES 's 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape |
02-13-2006, 04:21 PM | #3 |
MDC, thanks but this is a 65 Van so I'm pretty sure no junction block or fusible link. Haven't had the time to check it out yet.
02-13-2006, 05:12 PM | #4 |
More Cowbell....
You should still be able to ground the neg. cable of the battery to the frame (vice-grips). Other than that, you should be good to test. Just make sure the hot wire leading to the starter isn't touching metal first....ZZZZZAP!.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
02-13-2006, 07:19 PM | #5 |
safer to use a battery charger set to low amps, that way anything wrong you shouldnt fry anything.
72 chevy C-10 swb fleetside,402 BB.700r4,buckets,console.etc. 72 Blazer CST 350,AT, new project 1971 Chevy Nova ,355 SB blow through turbo in works. |
02-13-2006, 07:28 PM | #6 |
Good idea for the battery charger -
So where should positive be connected to? No junction block nor starter so no positive battery cable. Perhaps starter wires? Thanks guys. |
02-13-2006, 08:36 PM | #7 |
its all about the +6 inches
One one end of the positive cable or the other, there should be a smaller wire that feeds the whole van. I understand there is nn actual cable, but down by where the starter should be, or up by the battery, somewhere around one of those two places, there is a wire that feeds the entire van.
02-13-2006, 11:07 PM | #8 | |
Vortec in the works
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
