Old 07-20-2002, 09:56 PM   #1
Cheyenne Super
? for those with air bags.
what are you going to do with you exhaust system?
the problem i will be runing in to is getting over the axle with out innference when the truck is all the way slammed.
I don't want to stop the exhaust before the axle due to back pressure issues.
1971 Cheyenne Super
Soon to be converted to '68 front clip.
Efland, NC
Cheyenne Super is offline   Reply With Quote
Old 07-20-2002, 11:04 PM   #2
PushinPebbles
My dad's 68
PushinPebbles's Avatar
You run block hugger headers and run the exhuast to the front of the rear axle.........................but most bagged trucks don't run their exhuast past the axle.................alot of work w/ the big notches .....................um another way is to run the headers that go over the frame rails......like on the old impalas and tri-fives........
hope this helps
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
grand dads truck 68 C-10 stepside
fuel inj. 350/700R-4*soon in audi silver*
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
Old 07-20-2002, 11:10 PM   #3
Low69CST
I have a friend with a bagged 40 Chevy. He had the same problem and ended up with his exhaust ran under is axle instead of over. Also, if you don't have a blazer tank, i've seen people run exhaust through holes in the cross member right behind the rear end. That might give you a little extra room.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-20-2002, 11:23 PM   #4
Shane
Shane's Avatar
under the axle??? How does that work???
The exhaust must be connected to the frame somewhere (engine mounted to frame and exhaust mounted to engine)....and therefore, when the bags are deflated the exhaust is gonna drop too.....if its under the axle, where is it gonna drop.....on the ground???
Please explain....im not sure I understand.....
Shane is offline   Reply With Quote
Old 07-20-2002, 11:27 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If back pressure is the only thing you are worried about.....don't worry about it. By the time the exhaust gets all the way back there, it has cooled enough that it just doesn't matter. You could run straight pipe with out mufflers, and by the time you got all the way to your axle it still wouldn't matter.
Old 07-20-2002, 11:30 PM   #6
Low69CST
Well, first he's got a 40 chevy 4 door sedan. It has no where near the wheel travel our trucks do, so that cuts down on how far down the pipes have to turn down to clear the rear axle. The back of his car sits pretty low, so when it deflates, it only drops a few inches. He's got it the pipe droped down just far enough it clears the axle when driving and tucked up enough it doesn't touch the ground when he lets the air out. Slick set up.
Old 07-21-2002, 12:17 AM   #7
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Talking
I Have ran bags for some time now. The reason the exhaust usually stops at the rear is, IT IS EASIEST. I looked under my bagged 68 there is still alot of room to get over the axle unless you did a body drop or MONSTER C-notch it should be no problem to get it out the back. The problem is finding an exaust guy willing to do the bends. I found that alot of shops will flat out tell you NO!!! Simply cause it will be to involved, not that it can't be done. JMO had to throw my 2cents in. Hope I didn't offend any exhaust guys. But the ones around the valley are pretty LAZY, as far as puttin in the bend time for a full custom exhaust.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 07-21-2002, 08:20 AM   #8
Cheyenne Super
nsane68 i agree with you
about the exhaust shop issue. btw did you have exhaust out the rear of the primer yellow truck on you website?
on the backpresure issue i am not so much worried about the temperature and backfiring as i am losing low end torque.
when i first bought my truck it had 2.5 exhaust exiting out the rear. i redid the exhaust w/ 2.5 in front of the rear tires. although it helps top end the bottom end isn't so good anymore.
i won't me monster notching the frame. I don't want to sacrifice the bed for the center section of the axle.
1971 Cheyenne Super
Efland, NC
Old 07-21-2002, 08:47 AM   #9
XXL
Seņor Member
XXL's Avatar
Re: nsane68 i agree with you
1) Consider 2.25" exhaust. Backpressure is just basic math of "how much can you flow out of a tube?" If you shorten the tube, you can reduce the diameter and get the same results. The limitation here is that you can make an exhaust ANY length but you can't have ANY diameter pipe (because they don't make too many sizes), but you can get pretty darn close.
2) For notching the frame, etc-- my notch is the basic Classic Performance C-section kit...
which doesn't even go through the top side of the frame. I raised my bed floor a meager 2" and at full drop the pumpkin doesn't poke through... so I still have a flat bed floor. And mine still gets pretty low...
Kenneth
XXL is offline   Reply With Quote
Old 07-21-2002, 08:31 PM   #10
Cheyenne Super
xxl
what air bag kits do you have?
I will use the classic performance c-notch as well. I took some close measurements and I will be able to run the exhaust all the way out the back, that is if I get creative.
thanks
1971 Cheyenne Super
Efland, NC
Old 07-21-2002, 09:11 PM   #11
XXL
Seņor Member
XXL's Avatar
Re: xxl
I'm using the kit from Air Ride Technologies. I highly recommend the guys at Air Ride for their superb support and their well-designed kits. Having said that... if you go with their kit, save yourself some trouble and upgrade to at least a 3 gallon air tank and the appropriate compressor. I started with the 2 gallon tank and it was not enough air to push the truck all the way up, so I had to cycle the compressor every time. That made lift times around the 2 minute range . I now have 2 3 gallon tanks, and 2 315 compressors to keep them filled, as well as their 4-way RidePro valves. I can drop the truck to the ground and lift it back up in under 8 seconds. I'm not into the hopping scene but I do want to be able to lift and go when I want to and not have to wait on the air supply!
If you check out my web site (link below) I've got a few pics of the current configuration. Also... here's a schematic of the current layout (Adobe Acrobat Reader required).
Kenneth
Old 07-21-2002, 09:47 PM   #12
Reumster
L.E.D. Freak
Reumster's Avatar
Question XXL?
You said you raised your bed floor 2"??? Is that required for the Classic Performance C-section kit? I was considering that for my Blazer.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 07-21-2002, 09:58 PM   #13
XXL
Seņor Member
XXL's Avatar
Re: XXL?
I don't have the bump stops in place because when I drive the truck, it's aired up... so has lots of clearance. Hence when I drop it I get an extra 1/5" or so of drop before the frame and axle meet. Because of this I needed clearance for the pumpkin. So... if you're using the bump stops you should be fine without cutting your Blazer floor.
Kenneth
Old 07-21-2002, 10:08 PM   #14
Reumster
L.E.D. Freak
Reumster's Avatar
XXL
Thanks for the info.
I have one more question, can you get a electric controler for the bags to automatically go to say, ride height, pancake, and all the way up? with the touch of a switch?
(406)675-8082
Old 07-22-2002, 05:47 AM   #15
XXL
Seņor Member
XXL's Avatar
Re: XXL
Yes, they're available in a few different styles. Try AIM or GodFather's (you've probably seen their "catalogs" in Truckin'). I just added a 5th (ON)-OFF-(ON) switch with the outputs paralleled into the other 4 switches' "up" and "down" so teh 5th switch is like I was hitting the other 4 at once. Because of slight variances in fill rates, and because of different requirements for front and rear pressures, I still have to make minor adjustments for ride height once it's up and rolling. But dropping it is a matter of pushing a single button for a few seconds.
Kenneth
Old 07-22-2002, 01:02 PM   #16
fastbagged68
fastbagged68's Avatar
I ran my exhaust under my axle. When air out the exhaust sits about an 1/8" off the ground then when its air all the way up its 1/8" below the axle. If I drive down the street with it aired out the exhaust does a nice spark show. I did that a few times to make the exhaust flat to give me more clearance. My exhuast never hits when i'm driving at ride hieght. You need to run at least 6 gallons of air at around 150psi in the tanks to make the car lift. i have 3/8" valves but soon to put on my Parker 1/2" valves and i can raise my truck now in about 2 seconds. Thats about 9" of travel. Soon to be hopefully a split sceond to lift the truck.
fastbagged68 is offline   Reply With Quote
Old 07-22-2002, 03:08 PM   #17
jay-dawg
chevelito
jay-dawg's Avatar
he he he he...cool!!!! he he he he ( in my worst butthead impersonation).
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
