Old 02-14-2006, 09:10 AM   #1
Jim85IROC
Jim85IROC's Avatar
Code 51: PROM Failure
Not what I expected when I came out to the truck this morning. I started the truck and went back inside, and when I came back, the SES light was flashing at a very quick rate, which is something I've never seen a GM light do before. Of course the batteries were dead in my scan tool, and my 2nd set of batteries weren't worth a damn either. I hopped in and tried to drive, and it drove fine. I headed to work, and after a few minutes the light went out. It flickered one more time very briefly about 20 minutes later, but otherwise seems fine.
Is it possible that I've just got a poor connection where the MEMCAL plugs into the ECM, or is this likely to be bigger things?
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 02-14-2006, 01:01 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Code 51: PROM Failure
I haven't had to fix one with that code before. That sucks. Have you removed the MEMCAL lately?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-14-2006, 02:09 PM   #3
Jim85IROC
Jim85IROC's Avatar
nope. I haven't touched it since I owned the truck. Tonight I'll probably pull it out and reinstall it a couple times just to make sure the contacts are clean.
454
TH400
My Sounddomain Page
Old 02-14-2006, 04:28 PM   #4
Captkaos
Captkaos's Avatar
That is weird! Sounds like you have a plan. Let us know if it fixes it.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 02-14-2006, 07:56 PM   #5
jermasaurus
jermasaurus's Avatar
I had the EXACT same deal with an 87 monte carlo i had. Came on occasionaly, then the light stayed on constantly
I was worikng at a parts store so I was able to swap computers and put my chip in the new one. The light stayed off so I knew my chip was good.
I wouldn't have replaced it because it still ran perfecet and in closed loop, but they won't test the emissions with the light on.
Long story short- got a boneyard computer. Fixed it
Good Luck
-Jeremy
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
Old 02-15-2006, 09:25 AM   #6
Jim85IROC
Jim85IROC's Avatar
no problems on the way home from work and no problems this morning. I didn't get a chance to screw with it last night, but hopefully this weekend I'll yank the MEMCAL while I do the oil change I've been meaning to get to.
454
TH400
My Sounddomain Page
