Old 02-14-2006, 06:26 PM   #1
Miles
Help: Weird Timing Mark Location
Here’s a problem that has me stumped – any helpful info would be appreciated.
I had a 350ci crate engine put in my ’72 C-10 about a year ago and it has been running really well since. When I went to tune it up recently, I found that the timing was set at about 16 before TDC (manual transmission; I’ve been setting the timing at 8 before for the last 20 years with no problems!).
The distributor had not been messed with as far as I can tell, but I went ahead and had a local mechanic switch me over to electronic ignition. He timed the engine ‘by ear’ and found the timing mark to be around 18 before TDC when done. He told me that he checked to verify that when cylinder #1 is at TDC that the timing mark was at zero.
One thing I thought could be going on (however unlikely) is that the harmonic balance/damper may be defective – perhaps there has been slippage of the bonding elastomer connecting the inner-outer pieces which resulted in a mis-located mark? I thought I would see what other folks thought before removing the harmonic balance to check its alignment this since the part is only a year old and I assume it is OK.
I am a bit out of my league on this, so if there is more info needed, please direct me to what additional info you may need to track this issue down/clarify what’s going on.
Thanks in advance!
Miles
1972 Chevy C-10
Miles is offline   Reply With Quote
Old 02-14-2006, 08:31 PM   #2
mjrmn
'67 K10 Work In Process
mjrmn's Avatar
Re: Help: Weird Timing Mark Location
I think you may be right on the money with the idea of the outer ring of the balancer shifting. This can easily happen with new balancers or old. Especially if they are really revved up. Also may want to check with the engine supplier/installer to see if they have had similar problems with other engines they have done.
Good Luck!!
Mike
mjrmn is offline   Reply With Quote
Old 02-14-2006, 08:44 PM   #3
68 Stepside
huh?
68 Stepside's Avatar
I had a ZZ3 crate engine from GM in my 85 Z28, the balancer slipped on it, after less than 3,000 miles. I think you may be right on the money as well.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 02-14-2006, 10:23 PM   #4
jimfulco
Didn't they change the timing mark location by about 10 degrees sometime around the early '70s?
jimfulco is offline   Reply With Quote
Old 02-15-2006, 12:50 AM   #5
jhow66
jhow66's Avatar
Was this with advance hose on or off?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-15-2006, 01:03 AM   #6
al's71gmc
4 eyed fever
al's71gmc's Avatar
With the electronic ignition I thought you were supposed to set it at 12 before tdc? I read that somewhere??
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 02-15-2006, 01:11 AM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You need to go back to basics on the tune-up before getting too far off base.
What was the idle rpms when you checked it they should be set at 600 or near. Was the idle rpm set with a vacuum gauge and like Jhow said did you have the vacuum hose off the distributer and plugged .
If your mechanic said number 1 was at top dead center and the timing mark was on zero, what makes you think the outer ring has slipped?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
