Old 02-14-2006, 10:12 PM   #1
fade94
fade94's Avatar
Is there a way to tell what AN fitting size I have?
I have a fuel cell that I will be installing. How do I tell what size AN fittings I need for it?
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 02-14-2006, 10:57 PM   #2
Rally Nova
Rally Nova's Avatar
Re: Is there a way to tell what AN fitting size I have?
Most fuel cells have dual -8AN fittings coming out of the bottom sump, that I have dealt with. Are you going to us an electric pump or a mechanical? It also depends on your horsepower. I replaced mine with a -12AN on my '72 Nova.
1969 GMC C-1500
1972 Rally Nova
1988 Monte Carlo SS
2004 GMC 2500 Crew Cab
Rally Nova is offline   Reply With Quote
Old 02-15-2006, 08:56 AM   #3
fade94
fade94's Avatar
Due to the distance to the cell, I will be running an electric pump. HP will be in the 300-350 range. Nothing radical.
Old 02-15-2006, 11:28 AM   #4
BubbaGreen
AN-6 would be the absolute minimum, AN-8 (appx 1/2") would be a good choice...are you running carb or FI? If your running FI, would recommend AN-6 as the supply line and AN-8 as the return.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 02-15-2006, 02:19 PM   #5
Billla
Billla's Avatar
AN fittings are numbered by 1/6ths of an inch; an AN-8 fitting is 1/2", an AN-6 is 3/8".
It ain't high tech
Billla is offline   Reply With Quote
Old 02-15-2006, 02:54 PM   #6
fade94
fade94's Avatar
Reading my original, I need to clarify. How do I tell what size AN fitting is on the cell? It has 2 male fittings on it. I need to order my lines and fittings but I need to know what size to get to hook up to the cell.
Old 02-16-2006, 04:36 PM   #7
Rally Nova
Rally Nova's Avatar
They should be -8AN on your fuel cell. Are you going to drive it a lot on the street? Are you going with stainless braided line all the way?
1969 GMC C-1500
1972 Rally Nova
1988 Monte Carlo SS
Old 02-16-2006, 04:58 PM   #8
fade94
fade94's Avatar
Will be mostly street with track time as well. I'm still trying to decide if I want to go braided or not. Needed to know what size fittings I am looking for so I can budget everything in.
