Old 02-15-2006, 03:07 AM   #1
Ol'blue72
Question Tranny linkage question
Does anyone have photos of 71 and/or 72 shift linkages? My72 with a turbo 350 has a linkage that runs strait from the column to the tranny, but my 71 parts truck has a linkage that runs to a pivot bracket that is mounted on the frame. Which is better/more reliable. The strait link feels funny sometimes like it is not a positive positioning and will maybe move, if that makes any sense.
Ol'blue72 is offline   Reply With Quote
Old 02-15-2006, 03:32 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: Tranny linkage question
My 70 has the pivot bracket. The 72 parts truck had the same pivot bracket.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-15-2006, 04:48 AM   #3
13lazer
13lazers' blazers
13lazer's Avatar
Thumbs up Re: Tranny linkage question
on your '72 are you talking about an aftermarket cable linkage, or one from a different vehicle? i've only seen the pivot brackets. i had a b&m quicksilver floor shifter on my '61 apache 10 when i was in high school. the cable linkage sucked. i had to trust whatever dopey passenger i had to not kill me while i crawled under the truck to get it in park. it took me a while to fix things back then. if i were you i'd grab the pivot assembly. i use 1/2 of a spark plug boot and a cotter pin to keep mine secure.
13lazer is offline   Reply With Quote
Old 02-16-2006, 01:22 AM   #4
Ol'blue72
To 13lazer, no it is a normal shift rod. Krue i was told today that the pivot bracket had a spring on the pivot shaft which is not there now, what can i use if can't find one?
Old 02-16-2006, 03:06 AM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
here is a few pictures submitted by a board member.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-16-2006, 03:23 AM   #6
krue
Designated A-hole!
krue's Avatar
An amazing coincidence, but those are pics I posted the last time someone asked.
www.daveramsey.com
Old 02-16-2006, 03:24 AM   #7
krue
Designated A-hole!
krue's Avatar
It's hard to tell from the grease but in the bottom picture the spring has a washer on either end of it (slotted in the center but a regular washer would probably work).
www.daveramsey.com
Old 02-18-2006, 03:19 AM   #8
Ol'blue72
The arm on the tranny on mine is different, it is about 2-1/2" long with a couple bends and a hole for the linkage. i'll have to run the numbers an find out what i got. Thanks for the info an pics.
Old 02-18-2006, 12:08 PM   #9
kelsfine69
18 Till I Die
kelsfine69's Avatar
My suggestion is to go to a shift linkage from Lokar. I bought one and took out all that pivot stuff. Made it really clean and simple.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 02-18-2006, 12:50 PM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I saved them to my hard drive cause I knew someone would ask. I would have given you credit but I couldn't remember who posted them. I was thinking it was Andy or Tx Firefighter. Thanks again for the FAQS index. VV
VetteVet
Old 02-18-2006, 01:02 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Those aren't my pictures. I'm allergic to grease. Here's mine.
Old 02-18-2006, 06:14 PM   #12
BubbaGreen
Here are a few pics from my setup...
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 02-18-2006, 06:20 PM   #13
67shortie
Green club
67shortie's Avatar
My linkage is not like that last pic, twisted bracket style. Mine is straight and don't know if that makes a difference or not? Mentioning this because my linkage is at a wierd angle, binds up a little bit.
The truck was originally a 6cyl, now has a V8, what mouting location does the V8 need to be in on the franme? The front set of holes or the rear? Mine is on the front set, the HEI is about 2-3 inches from the firewall if that matters.
Sorry for the thread hijack
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 02-19-2006, 12:44 AM   #14
krue
Designated A-hole!
krue's Avatar
Whatcha trying to say? It's a lot cleaner now. Especially since I've replaced that seal.
www.daveramsey.com
Old 02-19-2006, 12:57 AM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The piece you describe sounds liek a later model automatic to me.
Old 02-19-2006, 03:30 AM   #16
Ol'blue72
looks most like the Lokar photo from kelsfine69, which would probably be my best bet. unless i change the arm on my tranny! what year tranny has the u-shaped arm on a th350?
Old 02-19-2006, 03:43 AM   #17
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
I had the same setup as above but I lost the spring also. I like to break motormounts and then the engine hopping would cause my shifting linkage to break all the time. I ended up fixing the motor mounts one last time and then welded to bolts the the plate that bolts to the transmission. This way i could screw nuts on over the other bracket and keep the hole dang thing nice and tight. Just a suggestion.
WRMZ71 is offline   Reply With Quote
Old 02-19-2006, 08:54 AM   #18
70GMCer
70GMCer's Avatar
I used Lokar also....easy to install, smooth shift, clean look. Does away with those brackets.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 02-19-2006, 12:13 PM   #19
sinister72
sinister72's Avatar
would like to see a few shots of the lokar setup if anyone has them!
72 chevy C-10 swb fleetside,402 BB.700r4,buckets,console.etc.
72 Blazer CST 350,AT, new project
1971 Chevy Nova ,355 SB blow through turbo in works.
sinister72 is offline   Reply With Quote
Old 02-19-2006, 12:27 PM   #20
Boog
laying low
Boog's Avatar
See post #9 above. Kelsfine69 has it.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
