Old 07-21-2002, 01:45 AM   #1
Billy Porter
Help Heater controls not working
Just replaced heater control unit..... Now no results.... Is the a ground on the things.... The fuse seems to be okay.... Help
71 GMC Stepside
250/350 Turbo better known as "Fred Sanford
77 240 Mercedes Benz
92 300E Mercedes Benz
70 Firebird 400
85 600 Ninja
Billy Porter is offline   Reply With Quote
Old 07-22-2002, 02:22 AM   #2
BIG ORANGE
BIG ORANGE's Avatar
Wink ???????
Was it working before you changed your controls,check your blower motor maybe it's gone bad.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 07-22-2002, 02:56 AM   #3
Andy4639
Old member
Andy4639's Avatar
Cool Heater controls
Need more info on what was wrong to begin with.
If the fan wasn't working to begin with check under the hood at the back side of fan to make sure the wiring is in place.
If that looks ok then start with a test light and try it at the switch. Check to see if you have power to the fan switch.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
