Old 02-15-2006, 07:51 PM   #1
JAKES 68GMC
Aluminum slot wheels rule...
67-72 4x4 t-case
Did most 67-72 Chevy/GMC trucks have divorced or married t-cases?
I have a married Rockwell 221 that has internal issues, and probably will need to convert to an NP 205 sometime, which doesn't seem to be any big deal according to past threads. Which is better, divorced or married? Is it any harder to swap from a married t-case to a divorced one?
Jake
JAKES 68GMC is offline   Reply With Quote
Old 02-15-2006, 10:50 PM   #2
Re: 67-72 4x4 t-case
More married t-cases.Doesn`t a divorced set-up need a trans and a t-case crossmember?The front d-shaft will be longer and the rear d-shaft will be shorter.You`ll need the t-case linkage for a divorced set-up.
Old 02-15-2006, 10:51 PM   #3
1969 GMC
1969 GMC's Avatar
If you are just going to replace your transfer case, the easiest swap would be to either another married Rockwell, or a married NP205. You'd need the adapter and sleeve out of the 205 donor vehicle, and then the x-member would have to go back a little bit. And the driveshafts would need attention then too.
If you went divorced, you'd have to get a 2wd tranny (or rebuild your current 465 with 2wd parts), a divorced transfer case, and then the jack shaft (that goes between tranny and transfer). I don't know if you could keep the stock x-member, perhaps if you found a divorced T221. Then you'd have to fabricate a linkage.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-16-2006, 05:14 PM   #4
JAKES 68GMC
Ok thanks.
Old 02-17-2006, 09:50 AM   #5
smokekiki
Mike
smokekiki's Avatar
The one tons had divorced transfer cases.They were conversions.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
