6 stud standard?
just a quick question on if all 6 lug wheels are the same spacing or are they different from vehicle brand to brand?
Found some rims from a 1990 Suburban and wonder if the 6 lug stayed the same till then and up into any newer trucks? Thanks for any info... Hagen
'70 Malibu with 383 stroker/T350 '56 SWB Mercury pickup..under construction '67 Firebird Convertible...all done stock '70 LWB 350 on propane...beater '69 LWB 350/T400 body restored |
Where's my beer?
Re: 6 stud standard?
I beleive they stayed the same, the only difference might be when you get 4x4 wheels, the hole for the center hub may be different size than a 2wd.
Paul How do you make the invisible, visible?.........You take it away. |
18 Till I Die
I got 86 4x4 ralleys on my 69 and they fit ok. A lot of guys do this.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
The only other problem would be early drum-type 2wd on later disc 4wd.Also,the 88-up type are more inboard/less dish or narrower track.I see the wheels in question are from a`90 Suburban.So,that`s a 4wd and you`re fine.
its all about the +6 inches
6 lug AMC fit too, but you have to open up the center hols a little.
Those '90 burb wheels MAY have a real small center hole that won't work on the older hubs, and the back spacing would be WAY off and look flat out retarded. Last edited by Longhorn Man; 02-16-2006 at 12:10 AM. |
open up the center hole a little.
The back spacing on them are a little funny too. I had 70-something wagoneer wheels on the front of my 69 GMC SWB. They were tucked in just a bit too much for my taste, and the rear ones woulda rubbed with the 275 wide rubber in back. (which is why I never looked for the others to make a complete set) Last edited by Longhorn Man; 02-16-2006 at 12:38 AM. |
#7 | |
