Old 02-16-2006, 03:45 AM   #1
MDC
MDC's Avatar
Intake Manifold Bolts?
Stupid Question
Are small block intake bolts grade 8 or just run of the mill 3/8 bolts. If so, can I use stainless? If not, where to buy the correct ones?
67 C10 Shortbed 327
05 F150 4x4 NO APPOLOGIES 's
02 Xpress X19 02 Yamaha VMax 150
www.xpressboats.com
Nothing says 'poor craftmanship' like wrinkles in your duct tape
MDC is offline   Reply With Quote
Old 02-16-2006, 05:42 AM   #2
Mudder
Post Whore
Mudder's Avatar
Re: Intake Manifold Bolts?
I got my stainless from Summit. I would use anti sease(sp) on them
Mudder is offline   Reply With Quote
Old 02-16-2006, 02:43 PM   #3
70c10
67-72 Addict!
70c10's Avatar
I bought Mr. gasket ones locally. I can't get mine to seal though.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-16-2006, 03:43 PM   #4
Bowtie67
Bowtie67's Avatar
they are run of the mill bolts, I like using the smaller head ones, they are easier to deal with.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 02-16-2006, 07:56 PM   #5
MDC
MDC's Avatar
Thanks for the help guys
67 C10 Shortbed 327
www.xpressboats.com
Old 02-16-2006, 10:00 PM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
If you're using stainless, there can be problems with them if they aren't properly heat-treated. I would only buy made in USA. If you buy at the hardware store, get at least grade 5 bolts. If you need a small head go with socket head cap screws.
Also, if you have aluminum heads, don't use stainless. Even with hi-temp anti-sieze you can loose the seal and galvanic corrosion will then occur.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-16-2006, 10:10 PM   #7
kelsfine69
18 Till I Die
kelsfine69's Avatar
ARP makes a nice set in stainless, good quality too, and the trick is to put that liquid pipesealer on the threads, not thread tape.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
