Old 02-16-2006, 07:35 PM   #1
farside847
farside847's Avatar
1 MPG gain
One full tank of gas since I switched to an electric fan, this mod alone
saved me 1 MPG. So I went from 13.2mpg to 14.6mpg. Thought you all
might like to know.
Electric fan swap: http://67-72chevytrucks.com/vboard/s...d.php?t=187724
Truck info: 307V8, 2b carb, 3sp manual, 3.73 rear
Driving: 35 miles per day in the lovely Bay Area traffic. Blech.
Wasnt as big of an improvement as I might have hoped, but hell, its
better than nothing, right?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 02-16-2006, 07:39 PM   #2
shifty
Questionable
shifty's Avatar
Re: 1 MPG gain
Just saved yourself $2.50 or more per fillup. If you fill up twice a week, that's $5 saved per week, $20 per month on average which nets you a free half a tank of gas or so, right?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-17-2006, 10:11 PM   #3
davidh
davidh's Avatar
Re: 1 MPG gain
How did you set it up? Did you have to take off the fan shroud? Thermostat for the fans? How much did it cost to do this? I have a 6cy truck 3speed that I was going to put in a 8cyl and keep in the 6cyl positon so this would be good if I am going to use the short water pump. Pictures would be good to. You say 307. all stock 2bbl. Would HEI and a 4bbl help too since the primaries would be smaller?
davidh is offline   Reply With Quote
Old 02-18-2006, 01:05 AM   #4
72MARIO
72MARIO's Avatar
Re: 1 MPG gain
That's good to hear.
That would get me 15 MPG I might consider that for my 84 DD. Now that I have done a cam swap I got the power band down low where I needed it the fule MPG is much better.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-18-2006, 09:35 AM   #5
Huck
Huck's Avatar
Re: 1 MPG gain
Switch from the 373 rear to a 307 and get a 4+mpg improvement on highway. It will also give your engine a extended life!! Switch to an overdrive transmission too and you will get another 3+mpg!! Just think, do all these modifications and you will put the arabs back into their tents!! hehehe
Huck is offline   Reply With Quote
Old 02-18-2006, 03:22 PM   #6
72MARIO
72MARIO's Avatar
Re: 1 MPG gain
I think the 3:73 are doning great. The 3:07 tends to bog the motor down and loose MPG.
2005 TAHOE DD
Old 02-18-2006, 06:37 PM   #7
Truck Hippy
Truck Hippy's Avatar
Re: 1 MPG gain
I went the 307/700r4/308 set up before, It wasn't pretty. I had a 70' swb driver. I put in a 307 out of another truck with low miles, still had the 2 barrel, put in a rebuilt 700. Motor ran great. Probably one of the best running motors I have ever had as far a being smooth and didn't use oil. Well on the open road The over drive with the 308 gear killed the poor little motor and I had to really mash it down to mantain speed on any kind of a hill. I shoulda kept the 373 gear. Live and learn. By the way I put the turbo 350 back in and with a super tuneup and driving like grandma, I pulled down 17.2 mpg with that heap.
Truck Hippy is offline   Reply With Quote
Old 02-19-2006, 06:51 AM   #8
vtblazer
vtblazer's Avatar
Re: 1 MPG gain
Was the fan you removed a direct drive/flex or a clutch fan?
vtblazer is offline   Reply With Quote
Old 02-19-2006, 11:29 AM   #9
Boog
laying low
Boog's Avatar
Re: 1 MPG gain
I would like to see more of a 3 to 4 mpg improvement by going electric before I converted one. Obviously the electric fan will make a major improvement over one with the direct drive fan but I'm not so sure it will make that much difference over one with a properly operating oem clutch fan. I see mention of cfm ratings of the electrics. I have never seen mention of cfm ratings of the clutch type. Just how much air does the clutch fan pull? For a truck like farside's with no a/c his fan will probably do just fine, even in heavy traffic idleing but for the guys running power steering and a/c in summer heat they may have a problem with the single fan. There is at least one guy who installed a Lincoln mark8 fan setup. Sounds like it might be heavy duty enough. Anyone used the dual fan setup from the later model Chevy trucks yet?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-19-2006, 02:31 PM   #10
davidh
davidh's Avatar
Re: 1 MPG gain
I'm thinking of this swap of fans, 305(80's HO Fbody) with rv cam, keeping the 3speed manual, and 3.08's. Maybe some mileage then.
Old 02-20-2006, 12:19 PM   #11
farside847
farside847's Avatar
Re: 1 MPG gain
Here is the thread of the fan setup.
I had a manual (non-clutch) fan setup before.
