which size fit my blazer
Which size will fit my blazer. My friend has a pair and we think they will fit but i want to make sure. The backspacing is the issue i have in question. The rims he has a 15" and they are the correct bolt pattern. No, i wont be selling the stock wheels either
![]() http://www.4wheelparts.com/4wp/produ...HEELS&man=TECH Last edited by Medicanman71; 02-16-2006 at 10:57 PM. |
The Blazer King
Re: which size fit my blazer
I'm gonna go with:
16.5x12" 5 or 6 lug w/5" backspacing PCW51-65285 I would add some accessories of 12 inch lift and some 38x15.50's. ![]()
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
bahhh i just got 1/2 that amount of lift and 33's
I'm not asking wich, i'm sorry i was a bit blzd when i posted that before... i have stock 15" blazer rims... , so i'm pretty sure the tires will fit with said wheels, and i'm pretty sure the bolt patern and spacing is correct, i'm just worried is there any backspacing issues i should worry about or will they fit NP? |
![]() ![]() ![]() I think the black rims will go nice, and i'm going to get them for a song I think they should stick out a bit wider too Last edited by Medicanman71; 02-16-2006 at 11:02 PM. |
Looks like your only choices are the 8" or 10" width with 3.5" backspace.
You could try it, but I don't think there's any way the 16.5" wheels with 5" backspace will clear the tie rod ends in front. Besides, the 16.5" wheels have a weak lip that will pop the tires if you air them down. I've got 16" wheels with a 4" backspace and they sit pretty close to the rod ends. 16" with a 4.5" backspace hits.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
wait i have 15" rims.... whatcu talking 'bout?
![]() ok these are the wheels in question |
black steel wheels would be a visual down-grade. stick with the stock rally's, they look ton's better
-Cameron
1972 Dark blue, Cst, Highlander |
haha, o.k.....
heh, that seems to be the big thing with guy/kids around my area, black steel wheels. guess i never caught on, but your rig, your taste
But alcoa's or rally's for me ![]()
I think i'd mount a better pair of tires for the sand like some baja claws on them if i got them if i started mobbing the dunes alot more often once it warms up ( haha as if 60-70's arent warm enough). I'd keep these tires and wheels the way they are. I like these rims alot, but wouldnt mind some change
Visual downgrade?That`s a matter of opinion.Here`s your Blazer on steroids:
![]() ![]() What size tires are you wanting to use and how much lift is that?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-17-2006 at 07:52 AM. |
#12 | |
I used to think the same way until I started bashed around in the rocks and such. I just took oof a sweet set of Weld alloy wheels and installed those black steelies that I always said I'd never run. NOTE: this is for the off road abuse truck though. I still prefer rally's or alloy's for the street any day. Med71 - 33's fit stock w/moderate wheeling. (BobbyK does even better) 4" lift w/33's is good for wheeling. 4" lift w/35's and your back to moderate 6" lift w/35's your good to go again Typical 'will fit' is a 3.5/4" back spacing, anything more and what RestoRod say's is true. |
#13 |
Nice wheel
![]() "Typical 'will fit' is a 3.5/4" back spacing, anything more and what RestoRod say's is true" - this is what i was looking for - thanks guys! special K - i've had that mag for a while ![]() As far as tire size goes, i think i'm set for now, and with 33's and 6" lift..., well, i dont think i need to worry about running... I went w/ 33's unlike 35's like most, so i can stuff them more, and unfortunatly most of my mobbing is still ON the roads/highways. The truck for sure stops and goes faster with the 33"s vs. anything larger. ![]() my lift makes my 33"s look mad small ![]() Last edited by Medicanman71; 02-17-2006 at 02:46 PM. |
#14 |
BTW,Medicanman71,I like your Blazer.I gather you`re in the Central Coast somewhere?Must be nice to run around the area in that.Just take it easy on the wine,watch those surfer girls(they can be a little wild),and don`t touch the gum on the wall.lol
Here`s mine: ![]() Damn,forgot to polish them first.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-18-2006 at 10:24 AM. |
#15 |
Those late model rally centers look good like that.
#16 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Hey special k you got any bigger pics of the offroad unlimited blazer???? BTW shinny wheels for the street and black ones for offroad....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#17 |
Thanks for noticing,VT.I didn`t want chrome,they`re cheap to replace,I had them laying around....
Hey FRENCHBLUE72,I don`t know how to resize.I got them off of Offroad Unlimited`s site.See if this is different: ![]()
#18 |
PROJECT 7DEUCE
Thats a sweet pic those body lines sure don't seem like they like being stood up like that..
#19 |
Yeah,it hurts to watch.
#20 |
Right about then I think I would have pooped my pants.
#21 | |
#22 |
hey what's that BEAST behind your blue blazer?!?!?
#23 | |
Talk about small! Kinda cool though. ![]() |
#24 | |
I miss this truck.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#25 |
Does it fit in the back of a blazer?
