Cantankerous Geezer
Washer spray nozzle replacement?
What is anyone using for replacements on the windshield washer spray nozzles? Mine are full of rust and paint, so I doubt if they will spray right.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Re: Washer spray nozzle replacement?
Buy new ones from the vendors.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Old member
Here is a idea for you. I went this route and it all runs off the factory wiper control in the truck. I added sprayers from a small import on the wiper arm and the water jug. It has the electric pump built into it. This works great because it sprayes the whole windsheild while the arm is moving.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#4 | |
Cantankerous Geezer
#5 | |
do you remember what import that washer bottle came out of? i've been looking for one myself, but most are not as compact as that. |
87 up trucks have the pump built in to th tank. 95 grand prix have the nice squriter like the one in the pics.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Old member
If I remember correct it was a old corala, I think. Sorry but it's been some time ago when I did it.Just so some of you know. Once I got the sprayer's home I boiled a pot of water on my Kerosene heater and fit tested the sprayer on my arm and then used a pair of vise grips to hold it in place and set in the water to make the sprayer conform to the arm so it wouldn't fall off.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 02-18-2006 at 10:19 AM. |
I know this is an old post, but it is as close to what I need as I could get.
I need to find out where/how the factory spray nozzles were mounted on the cowl. I like what csstanley has done, but prefer staying stock if I can. I have the nozzles but can't seem to figure out how to install them. If someone has a picture that would be great too. Any help would be appreciated. |
![]() Join Date: Feb 2004
Use this link and there are some pics of the washer nozzles and how they are mounted. they are mounted with screws
http://67-72chevytrucks.com/vboard/s...d.php?t=194094
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Thanks 72armyswbtruck. This is what I needed.
