Question on wires
Is the green wire on my comlum that goes into the turn signal switch the horn button?
And my brake lights stoped working tonight and I looked at the switch and there is a black wire thats not pluged in. Is that the ground? Where does that plug into?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
Re: Question on wires
The wire to the horn button is a black wire.
The brake light switch should have an orange wire and a white wire hooked to it. The black wire may be a ground wire as black wires by convention are usually used for grounds in these trucks. Jim |
The grey wire on my tilt colum is the "prndl" gear selector indicator, it ties into the dash light wiring.
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
It's a catastrophic success.
![]() Join Date: Jan 2003
