Old 07-21-2002, 01:11 PM   #1
dion
72 Cheyenne
dion's Avatar
Will the H-Pipe give a better sound?
I have dual straight 2 1/4 pipes into flowmasters, will the H pipe set up give abetter sound? I'm having 2.5 pipes put in and wanted to get some input, thanks.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 07-21-2002, 01:13 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
They will sound a little differant...slightly more quiet.
Old 07-21-2002, 02:40 PM   #3
68 with 350 TPI
68 with 350 TPI's Avatar
It will sound a bit more tuned IMO.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-21-2002, 02:58 PM   #4
barn9
Half a bubble off!
barn9's Avatar
It made my truck sound better. I would never put on a dual exhaust system without the H pipe. It equalizes the two sides for a sweet even sound, loudness depends on the mufflers you use.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 07-21-2002, 03:05 PM   #5
crazy longhorn
Fabricate till you "puke"
Same here,I run an h pipe in every dual system since I tryed the first one.........a much "cleaner" sound........Al
crazy longhorn is offline   Reply With Quote
Old 07-21-2002, 06:39 PM   #6
Smitty
Smitty's Avatar
Dion will try to stop by after work tomorrow. Monday and you can check out my new exhaust system then and let me know what you think then. You'll be able to hear one for yourself!
Smitty
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 07-21-2002, 08:08 PM   #7
72ChevyCheyenne
72ChevyCheyenne's Avatar
I just had an H pipe put on my 72. Hedman headers with 3" pipes, Flowmaster 40s and big tips angled behind the tires. It really does make it sound tuned. I love it.
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 07-21-2002, 11:33 PM   #8
dion
72 Cheyenne
dion's Avatar
Cool, I just don't want to loose my low end rumble.
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 07-21-2002, 11:48 PM   #9
barn9
Half a bubble off!
barn9's Avatar
Your low end rumble will sound sweeter than ever! H pipe is the only way to go.
Just call me LB.
Old 07-22-2002, 02:58 AM   #10
68 Stepside
huh?
68 Stepside's Avatar
I agree Wilfred!
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-22-2002, 07:49 AM   #11
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
adding an hpipe made my exhuast resonate more
-Nic
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
Old 07-22-2002, 11:54 AM   #12
WB72
Before and After
WB72's Avatar
Is there a way to determine where the crossover should be? would it depend on the size of pipe? I heard that you should run new exhaust for about 1/2 Hour, the pipe will darken and that is where the optimum place for the H pipe. If this is true, it would take 2 trips to the muffer shop, who has time for that?
Where does you H pipe fit in your system, how far back from the end of the collector?
Just want to be able to do mine once.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 07-22-2002, 12:11 PM   #13
crazy longhorn
You can paint the pipes with some cheap paint, then run it a while to see where the paint stops burning..... that should be about the right place for the h pipe. with that said, on a street vehicle,i try to put the H pipe just behind the trans crossmember,as i dont need any extra heat under the trans pan,or the headaches of trying to remove the pan with a pipe in the way. ......Al
