Old 02-17-2006, 12:55 AM   #1
Billla
Billla's Avatar
Low-speed only on heater blower
I have a heater blower that just spins at "idle" speeds. I ass*u*me that the problem is in the pot attached to the switch, but could an electrical guru give me a troubleshooting approach/process if this is NOT the problem?
Thanks!
Billla is offline   Reply With Quote
Old 02-17-2006, 01:52 AM   #2
jhow66
jhow66's Avatar
Re: Low-speed only on heater blower
AC or not?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-17-2006, 10:48 AM   #3
Billla
Billla's Avatar
NON A/C - should have noted that. It's a *very* base Custom/10
Old 02-17-2006, 11:08 AM   #4
jhow66
jhow66's Avatar
Most likely your blower resistor--trace wires to heater box from switch--will loke like coils of wire. To check blower motor remove wire from motor and run a jumper wire from + post of bat. If it runs at full speed your problem is in the resistor or the switch itself.
Old 02-24-2008, 05:40 AM   #5
Billla
Billla's Avatar
Follow-up since I finally just got around to it...it only took me 2 years
I replaced the blower resistor to no effect. The blower runs full speed with a jumper to the motor directly.
heading out to replace the switch right now I'm usually not a "parts changer" but the consensus seemed to be pretty focused on the resistor as the source, and it was cheap I'll also check the relay while I'm looking.
