Life, Be In It.....
![]() Join Date: Oct 2003
Step Side Tail Gate Latch
Does anyone know which company made the latches for the step side tail gate? I want to eliminate the stock latches and chains. The latch was built into the top rail of the tail gate.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
Granddad's Ol' Truck
Re: Step Side Tail Gate Latch
You might want to send Putter a pm on that. He did that on his truck.
1971 Chevrolet Custom 10 short step-side 2005 GMC Sierra SLT 2500HD crew cab 2wd [I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side |
C10 Club Tennessee
I'd be interested in that also. Great Putter-RESPOND!!
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
![]() Join Date: Aug 2005
Here's what you're looking for http://www.classicperform.com/stealthlatch.htm
#5 | |
Life, Be In It.....
Yes, Thats the one. Thanks Frizzle Fry.
two more.
http://www.pros-pick.com/hiddenlatchkits.html http://www.mar-k.com/41-53TAILGATEWHANDLEORIGINALBS.pdf
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
C10 Club Tennessee
That first one looks good. I just wonder how hard it would be to do on a semi-finished truck.
Bryan
Life, Be In It.....
![]() Join Date: Apr 2005
Here's some pics of mine. I used some pieces from the stealth latch, but fabbed the rest. I did this all to a factory 48 tailgate (inside the teardrop pocket).
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-17-2006 at 08:53 PM. |
More pics.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Life, Be In It.....
Hart Rod,
I don't suppose you have step by step instructions? How did you mount the support hindges and did you have to cut the inside of the tail gate?
#12 | |
![]() Join Date: Jul 2005
![]() Quote:
#13 |
More Cowbell....
Here is what I did.....Using Nissan Hardbody hangers....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 02-18-2006 at 05:54 PM. |
#14 |
C10 Club Tennessee
Putter,
What did you use to latch the tailgate up top. I see the hangers idea and like that.
#15 | |
Rob
#16 | |
I don't really have a step by step. The 48-53 tailgate is a little different than the one that fits the 54-87. You can use the hangers like Putter's, you'll just have to do a little mearsuring. I welded nuts to my tailgate and to and a stud to the bed. You'll have to notch the tailgate also so the hangers will work. This was the easy part. The reversed handle inside the rolled teardrop was the hard part. I used the spring loaded latches that Putter used (you have to drill a hole in the bed end for them to go through). I made the handle out of a door hinge (local hardware store). I cut a hole in the back side of the tailgate just big enough for the handle. You could weld this in but I cut a piece of 1/2 barstock, drilled and tapped it so I could bolt my handle to it. Then I welded it inside of the hole I cut for my handle. The handle took a little while to fabricate. I have cables coming from the Stealth latches, going through eyelets welded on the handle. I have more time in this tailgate than most people have in their entire bed! ![]() ![]() Rob
#17 |
More pics.
#18 |
Still more pics.......
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-18-2006 at 09:21 PM. |
#19 |
Last ones. I have all the parts to make another one if any one is interested.
Rob
#20 |
laying low
![]() Join Date: Mar 2001
Nice goin Rob.That is a clean approach to the tailgate mech. I like that so much I want to use that setup on my 69 step. I always hated those chains on my other trucks. This one is goin to be clean. You say those sliding latches and hangers are from a Nissan truck? Oh yeah, great looking '48 there.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#21 | |
Sliding latches are from CPP, they list them as stealth latches. Hangers or scissors to hold the tailgate up are from Nissan (I'm not sure what year). Thanks for the compliment. Rob
#22 |
Any ideas how this would work if you have a hard fiberglass tonneau cover?
__________________________________ 1971 GMC Stepside 350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar ________________________________ |
