02-17-2006, 08:33 PM | #1 |
Paint Amount ?
Will 1 gallon of enamel paint, using a H.V.L.P. spray gun, be enough to paint my 70 LWB? I am not going to be painting the inside of the bed, or the inside of the cab. I will be painting the door jams though. Just trying to get my material all together before the big day. I want to make sure I have enough paint on hand. Someone told me that 1 gallon would be enough.
steve
1997 GMC Sierra Ext 1965 Mustang |
02-17-2006, 08:50 PM | #2 |
Re: Paint Amount ?
A GALLON OF UNMIXED PAINT SHOULD BE PLENTY TO PAINT A LONG BED & JAMS. BY THE TIME YOU MIX IN THE HARDENER & REDUCER YOU'LL HAVE ABOUT A GALLON & A HALF. YOU WOULD PROBABLY HAVE ENOUGH TO PAINT THE INTERIOR TOO. SOME OF THE CHEAPER PAINTS (LIKE OMNI) ARE SUPER THIN TO BEGIN WITH, BUT FOR GOOD PAINT LIKE PPG.. A GALLON IS PLENTY. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 02-17-2006 at 08:54 PM. |
02-17-2006, 11:21 PM | #3 |
Re: Paint Amount ?
i am trying too find out the paint code for power blue paint for my friend
his chevy truck is 1967 or 1968 and it is yellow or white he wants power blue can any one help me out my email is chevyfiveohtwo@yahoo.com |
02-17-2006, 11:58 PM | #4 |
Re: Paint Amount ?
So far, I’ve used ½ gallon of Nason brand yellow single stage with a binks 69 on the inside of the cab. That includes the jams, inside doors, around the window frames and pillar post and under the cowl. My primer is dark gray and doesn’t cover easily. It’s going to take me at least two gallons to finish doing the bottom of the hood and inside the fenders and bed.
If you can't drive it park it! If you can't park it milk it! |
02-18-2006, 12:58 AM | #5 |
Re: Paint Amount ?
I used 3 gallons of torch red to do the whole truck. Thats inside the box under hood inside cab inner fenders grill.
A gallon and a half should be good just to do the outside of the truck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
