02-17-2006, 08:39 PM | #1 |
Junior Member
Power Steering Upgrade
Hi, I am upgrading from manual to power steering on my 1972 C-10 with a 307 motor, after doing a dry run on the install of the brackets and pump, I found I have a clearance problem with the alternator belt hitting the mounting bolt of the steering pump bracket, has anyone installed a p/s pump and did they have the same problem I have, and if so what did you do to correct the problem.Here's a couple of pics
http://i29.photobucket.com/albums/c2...gpumpfront.jpg http://i29.photobucket.com/albums/c2...e/MVC-010F.jpg |
02-17-2006, 11:01 PM | #2 |
Active Member
Re: Power Steering Upgrade
try a longer belt to the PS pump and move it futher towards the drivers side?? been awhile since i messed with that
________ Chrysler phoenix engine history Last edited by Jayss109; 04-27-2011 at 11:34 PM. |
02-17-2006, 11:04 PM | #3 |
the 67 i helped convert to power steering we just ran the alternator and power steering off one belt
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
02-17-2006, 11:06 PM | #4 |
Junior Member
I can move the pump, but the belt will still hit the bolt on the p/s pump bracket, thanks for the thought. And because of the stagger between the pump pulley and the alternator, I can't use one belt.
02-18-2006, 12:00 AM | #5 |
oh we used washers and longer bolt to line eerything up lol may someone got the answer for ya
02-18-2006, 12:16 AM | #6 |
"Trucks with Class"
You are fighting the old problem when you are running non-stock parts. That is not 72 correct PS or pulleys, so you have to hack/modify to try and get it to work.
02-18-2006, 12:27 AM | #7 |
Yep, nuts, bolts, spacers. It's trial by error. I had a 4x4 I added headers to and the front header bolt used the pwr steering bracket. I used a piece of conduit to space it. Have a little patience. Try to find a local truck set up as yours for a model.
02-18-2006, 12:40 AM | #8 |
Better yet, try to go to a junkyard and get everything off one veheicle so it matches up
02-18-2006, 12:50 AM | #9 |
Its a Truck Thing......
I got my brackets and pulley from alan groves and it works perfect for any short water pump, as stated above your using a metric pump and its going to be trial and error, this will be the 2cnd v8 that will get there brackets this weekend.....
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
02-18-2006, 03:04 AM | #10 |
You can also think about movin the alt. to the pass. side with later model brackets. worked for me, but the heads have to be drilled for front mounts.
02-18-2006, 09:28 AM | #11 |
If you want air cond later- leave the alternator on the driver side. You can probably also fabricate your way around this. I used a modified Speedway Motors bracket for my power steering pump -- and fortunately still got to modify it. 8-)
