02-18-2006, 02:39 AM | #1 |
C10 now is a GMC
Jackpot!! Have Questions
Hey Guys,
This morning my Dad & I took his truck to a real small town east of here. On the way there, my Dad & I lost count after 15 '67-'72 trucks. About 5 were in peoples driveways, the others were either parked out in a field, by a barn with other junk, or being parted out. I can't believe I seen this many in one area. The Guy I went to see about a TH350 trans had something like 5 or 6 '71-'72 C10 swb trucks he was parting out, besides 1 '73-'87 truck I got the trans from. I felt bad for the one red '71-'72 swb stepside that was rolled. Now that all these trucks have 5 lugs, isn't there a difference in brakes from '71 & '72? I heard that '71 front brakes are more expensive than on the '72 trucks. How do I decode the VIN on these trucks? What's a good price to pay for the complete front IFS from hub to hub? Also what's a good price to pay for a '71-'72 rear end? I'm going to ask if he would want to do a trade, since at the moment I don't got alot of extra funds, since I bought the trans. lol TIA, David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
02-18-2006, 02:48 AM | #2 |
Life, Be In It.....
Re: Jackpot!! Have Questions
Would you share the location of the town? Please.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
02-18-2006, 03:00 AM | #3 |
C10 now is a GMC
You got a PM.
David
02-18-2006, 04:16 AM | #4 |
I tried to get $100 for a wheel to wheel setup from a 72 and had no luck, but maybe stuff where you live is harder to find. I personally wouldn't pay more than 100 bucks for it, same with the rearend unless it's a posi.
"You can take the man out of PA, but you can't take PA out of the man" |
02-18-2006, 07:11 AM | #5 |
its all about the +6 inches
VIN DECODER
Call a parts store on avalability of the calapers, rotors and pads.... I'm thinking you are right on that, I THINK 71 was a one year only disc brake set up, which if I am right on that, odds are they'll be discontinued in the near future. |
02-18-2006, 09:07 AM | #6 | |
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 02-18-2006 at 09:07 AM. |
02-18-2006, 10:39 AM | #7 |
Old member
71 brakes are not a problem at all they inter change with 73 and up, the exact same caliper except the hoses are angled off the caliper a little more back toward the truck. How do I know this you ask!
I just did a complete brake job on my 71 disc's. I had ordered the caliper's for my 71 and received the 73 calipers it was last Friday and didn't really feel like waiting till monday to reorder. So Satuday I decided to check them out on the truck. Guess what they worked. Just so you know I replaced rotor's, lines drums,pads,shoes, all the rubber hoses, all the coil springs,wheel cyclinders evrything on the brake sytem except the booster and master cyclinder and hard lines.
02-18-2006, 12:13 PM | #8 |
BlahBlahBlah
personally ive given up on trying to sell suspension pieces. ive given away complete front and rears. i even gave away a short frame last summer and i recently gave away a 4x4 chassis.
02-18-2006, 06:51 PM | #9 | |
Green club
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
02-19-2006, 02:47 AM | #10 |
C10 now is a GMC
Thanks for the replies Guys.
A few more questions on the rear ends. What types of gear ratios does the '67-'72 swb C10 have? Is there a specific gear ratio difference between the 10 bolt & 12 bolts? So I can use a '71 & '72 IFS no matter what then? Sweet. Craig, you got a PM. Thanks again, David
02-19-2006, 02:47 PM | #11 |
I'd like a 3.08 5lug somewhere in the OK area if someone knows where they are lying. (hint, hint)
02-19-2006, 03:03 PM | #12 |
no 10 bolt rears, only 12 bolt and dana.
3.07 3.73 4.10 I think there was another for big block 1/2 tons, but nothing coming to mind other than the 3.54, but that's in 3/4 ton and up trucks. |
02-20-2006, 11:18 AM | #13 |
If the truck was an automatic, probably 3.07. 3 speed, probably 3.73. Check the option sheet too.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
02-20-2006, 11:36 AM | #14 |
I bought a complete 71 set up from a yard for 100 bucks, the price also included the lines, power booster, master cylinder, and support brackets. I also snaked the connecting rod to the brake petal. I spent another 200 or so replacing the rotors, calipers, hoses, bushings, ball joints, tie rod ends, bearings, etc... you get the idea. As far as price difference between 71 and 72 Autozone or Advance (whichever one has the MOOG stuff, can't remember which at the moment, maybe both do?) anyway they had the same parts listed for 71 and 72 and for the same price. As far as rear-ends I can not find a 5 lug around here for under $200. I've tried. I gave up and bought a set of 6 lug rotors. (got a great deal on them from TxFirefighter) I guess it will be cool to tell people I have power disks on my 67 and they still see 6 lugs up front Did you know they are as rare as 4th door suburban?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-21-2006, 01:53 AM | #15 |
C10 now is a GMC
Thanks Guys.
I'll have to definately check the sticker on the glovebox door(s) when I go back. Thanks again, David
