Old 02-18-2006, 03:24 AM   #1
speednmark
speednmark's Avatar
Bogg down...why?
So ive replaced my HEI cap and rotor assmbly, about to replace the spark plugs...Problem is, when i floor it, my truck tends to bogg down-(stop accellerating) at around 2 to 4 grand rpm....Ive got a 350, 750 cfm carb. I dont know if this is a timing issue, or a carb issue..if its either, does anyone know who can help me time my truck/ and or tune my carb....I live in Austin Texas...can you help? or know someone that i can take it to? Thanx alot.
-Mark Taylor-
1970 Chevy C/10
speednmark is offline   Reply With Quote
Old 02-18-2006, 09:02 AM   #2
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
Re: Bogg down...why?
#1 is your timing set per spec? #2 is your vacuum advance working? Sounds like you have a timing - firing issue.
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 02-18-2006, 09:09 AM   #3
truckdude239
truckdude239's Avatar
i dont know if you carb has it but sounds like an accletor pump on the carb gone bad happened on my buddys honda
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-18-2006, 09:18 AM   #4
I'm suspecting carb issues myself. Like truck dude said maybe an accelerator pump or I am also thing a 750 cfm carb is a lot of carb for a stock 350 (I assume, since you didn't mention other mods). You may need to rebuild and rejet that carb so it doesn't wash out the engine.
Old 02-18-2006, 10:02 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Definitely check/replace the accelerator pump, but check the vacuum advance, too. It may be just fine, but it's difficult to look at it and see what it's doing.
Back in the day, we'd hook 'em up to a Sun diagnostic machine and check all kinds of stuff like cylinder balance, timing, etc.
But, I suspect the accelerator pump is the prime suspect although it should also be apparent on initial take off. If the pump is bad, it's bad all of the time, not just at higher RPM's. Do you ever just pat the gas pedal to get it to take off from a stop? If so, then it becomes more of a suspect. Also, check the choke pull-off, just to be sure it is working. Does the bog happen more after it has warmed up? If so, the pull-off could be bad. Make sure the choke is properly adjusted.
One more possibility: I once had a coil-to-distributor wire that would break down on hard acceleration.....had the same effect as turning off the key. A new set of wires solved that one.
Member Nr. 2770
Old 02-18-2006, 11:16 AM   #6
byrd
Union Electrician
byrd's Avatar
I Agree with chevloray on the last issue, I had a bad wire from the HEI pickup coil and would cut off like turningon/off will under hard acceleration. Wire was shorting out when the dizzy was advancing...
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 02-18-2006, 11:57 AM   #7
QKENUF4U
QKENUF4U's Avatar
i think carb myself but we dont have enough info on the motor itself , built ??? stock ???
QKENUF4U is offline   Reply With Quote
Old 02-18-2006, 12:21 PM   #8
Superron21
DONT TRY THIS AT HOME!
Superron21's Avatar
uh,
is your carb a quadrabog?
Superron21 is offline   Reply With Quote
Old 02-18-2006, 01:11 PM   #9
speednmark
speednmark's Avatar
This bogging down ONLY happens when the engine is under full throttle accelleration....its been rebuilt, bigger heads but no competition cam or intake...4 bl edelbrock 750 cfm carb.....keep it coming thanx
1970 Chevy C/10
Old 02-18-2006, 01:30 PM   #10
speednmark
speednmark's Avatar
Does anyone have a 650cfm carb for sale??
1970 Chevy C/10
Old 02-18-2006, 01:40 PM   #11
toolpimp
too many toys
toolpimp's Avatar
It could also very well be that the fuel cap is not vented. It does happen creating low pressure.
if we were all fatter we'd be closer together
1971 gmc 3/4 4x4 383 stroked
1968 1/2 2nd owner 4bbl 6cyl
1969 gmc 3/4 4 sale 350 4bbl 4spd
1969 chev 1/2 lowered 5 spd 454 4bbl
1947 chev coupe
2002 harley flhtcui
6 -67-72 my parts
toolpimp is offline   Reply With Quote
Old 02-18-2006, 02:23 PM   #12
GMCMAX
Active Member
GMCMAX's Avatar
It'll run fine slow, but dies out under full load acceleration?
Sounds to me like it's starving for fuel, either from a half plugged filter or a piece of trash in the secondary jet; the front 2 barrels carry it fine, the secondarys open up letting all that extra air in with no fuel to go with it.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 02-18-2006, 03:19 PM   #13
speednmark
speednmark's Avatar
Holy ****, my gas cap SEALS doesnt vent for ****. so when u take it off allll this pressure bursts out. That makes soo much sense....ill try a new cap and get back to yall. thanx lots...
1970 Chevy C/10
