02-18-2006, 09:41 AM | #1 |
alternator question
Looking to replace my alt with a 100 amp one wire chrome one. Anyone had any luck with the ones summit or jegs sells?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
02-18-2006, 10:12 AM | #2 |
Old member
Re: alternator question
Check this site out it may help you decide, I know it did for me. My opinion is I'll stick with what I have. I have the external regulator bypassed and run a three wire setup.
http://www.madelectrical.com/electrical-tech.shtml
02-18-2006, 10:17 AM | #3 |
I already have the one wire conversion and dont plan on changing just needing to go to 100 amp and like the chrome ones just wondering if they are any good.
02-18-2006, 10:26 AM | #4 |
Old member
OK, just thought it was some good reading. It showed me some things to redo on mine.
02-18-2006, 12:10 PM | #5 |
Not bagging you andy just have read it already and still like the one wire setup better. And really am just looking to see if any of the companies that jegs or summit sells are any good.
02-18-2006, 12:41 PM | #6 |
Msgt USAF Ret
why not go this route.
http://www.chevelles.com/techref/tecref14.html
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-18-2006, 01:05 PM | #7 |
Maybe I was not clear in my first post I am not looking to convert to anything I have a 1 wire alt now just want to up the amps to 100 and go chrome.
02-18-2006, 01:46 PM | #8 |
The powermaster alternators are pretty good stuff.
If you are looking for something extreme, check out this link: http://www.alternatorparts.com/
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
02-19-2006, 12:29 AM | #9 |
The only drawback with chromed alternators that I'm aware of is that the chroming doesn't dissipate heat as well as plain cast or billet aluminum housings. Cool temps help alternators last longer. That's why the best ones have heatsinks and extra or larger fan blades. Check if the chrome ones you're looking into have heatsinks and premium fan setups to compensate for the chrome's heat retention. If your truck has a low, overall amp draw, maybe it wouldn't matter, since alternator heat generation mostly occurs during charging.
With stamped steel valve covers, I think I've read that chromed stamped steel passes heat 80% worse than just painted stamped steel. But that was years ago that I read such things, so I can't be sure of the percentage. Just sure that chrome hampers heat dissipation.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
