Old 02-19-2006, 12:47 AM   #1
Wild83C10
Wild83C10's Avatar
Shortening a steering column
Has anyone shortened a steering column? Are the tilt columns shorter then a non-tilt column? What are my options if I want a shorter steering column? Thanks
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-19-2006, 01:09 AM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Re: Shortening a sterring column
I've never seen a shorter steering column for our trucks. If anything you're going to have to get an aftermarket one.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 02-19-2006, 04:27 AM   #3
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I don't know how hard it would be to lower the position of the column in regard to the dash (I don't know how it mounts), but you could partially collapse the intermediate shaft to give yourself more room.
badpeanut is offline   Reply With Quote
Old 02-19-2006, 08:54 AM   #4
OJOE
Crew Cut
OJOE's Avatar
you may want to try one out of a gm car like a grand prix
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 02-19-2006, 10:17 AM   #5
Wild83C10
Wild83C10's Avatar
Do you know any specific year that will fit without to much fabrication?
turbo=
Old 02-20-2006, 01:37 AM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Shortening a steering column
I had to shorten one for a Chevelle project I had a few years ago. I don't remember much about it, but it was a tilt 4spd column from a 77 Blazer...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 02-20-2006, 09:36 PM   #7
MidnightBlues
When my steering column broke down a few years ago, the only column I could find at that time was a 86 Caprice column. And I like it a lot. It's about 4 inches shorter. No more steering wheel in the belly and much easier to get behind the wheel. (And I'm really not that fat )
*Andre*
1984 C10 SWB, 350/700R4
MidnightBlues is offline   Reply With Quote
Old 03-02-2006, 08:08 PM   #8
wedgemon
wedgemon's Avatar
Did the Caprice column bolt in easily?
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 03-03-2006, 05:18 AM   #9
MidnightBlues
Well, you have to modify the column to dash bracket a bit. Nothing fancy. You can only use 2 of the 4 bolts there if you want to keep it simple. For the rest it's all identical.
*Andre*
