Old 02-19-2006, 10:16 AM   #1
Zeke
Active Member
rear brake drums
I have a 81 GMC 2wd 1/2 ton donor truck to upgrade my 69 to PS/PB and it looks like the rear brake backing plate will bolt on to the 69 rear. What I want to know is would 81 4x4 drums match up with the backing plate?
Also, if I swap the 69 rear for the 81 (lot of work) would 4x4 axles fit the 2wd rearend?
The drums and discs are shot, I bought 6 lug discs from GMC Pauls for the front conversion and would like to upgrade the rear also. Trying to get some ideas/options before I head off in a direction I'll regret latter $$.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 02-19-2006, 12:35 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: rear brake drums
Zeke I'm going to copy this to the 67-72 forum. I think you will get a better response there...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-19-2006, 12:54 PM   #3
dennislbrooks
dennislbrooks's Avatar
I doubt if you will gain any rear braking power by switching to the 81 unless they are the HD type. You will have to deal with the emergency brake cables also. Do you have other reasons to switch to the 81 3rd member?
If you were closer I would give you a nice oem 67-72 rear brake setup as I went to disc on the rear,
dennislbrooks is offline   Reply With Quote
Old 02-19-2006, 01:36 PM   #4
junkyardjohn
junkyardjohn's Avatar
I Bolted The Backing Plates & Complete Drum & Brake Assy. Off Of A 75 ONTO A 71 12 BOLT. They Were 2 5/8" Instead Of The 2" Wide Shoes That Came On Our Trucks. It Made A Very Noticable Difference. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 02-19-2006, 01:58 PM   #5
Boog
laying low
Boog's Avatar
ARe those 2 5/8" shoes the standard or heavy duty brakes in 75?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-19-2006, 02:22 PM   #6
davidh
davidh's Avatar
Doesn't classic enterprize offer upgrades for 71-2 rear brakes? Only thing is if you're keeping the 6lug you would have to have these redrilled or something.
davidh is offline   Reply With Quote
Old 02-19-2006, 02:43 PM   #7
Zeke
Active Member
They are the HD type and I was trying to keep 6 lug. Since the drums/discs were shot on the 81 and I bought the 6 lug disc and was wondering if the 81 6 lug 4x4 drums would fit the 69 axle with 81 2wd backing plate.
I would rather not redrill the drums since I need new ones.
1969 C10 350 3spd
Old 02-19-2006, 04:02 PM   #8
junkyardjohn
THERE WAS NOTHING SPECIAL ABOUT THE 75. I THOUGHT THEY WERE ALL 2 5/8" WIDE IN LATER YEARS. IT WAS A NATURAL PROGRESSION OF BRAKE SHOES. I KNOW MY 82 1/2 TON HAS 2 5/8" WIDE SHOES & IT IS NOT A HEAVY DUTY MODEL & DOESN'T HAVE EXTRA HEAVY DUTY BRAKES. JOHN
EVERY 2WD 1/2 TON AFTER 1970 HAD 5 LUGS.
junkyardjohn
DON'T RENT U-HAUL
