Old 02-19-2006, 08:32 PM   #1
76bonanza
76bonanza's Avatar
alternator question 2
the 10si and 12si cases what is the difference and how do I know which I have? Also I want 100 amp but may get a 140 amp for about 20.00 dollars more will the extra amps have any bad affect on me? What guage wire should run from bat to alt? In one wire hook up for 100 and 140 amp?
Sorry all the questions than\ks.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 02-19-2006, 10:36 PM   #2
Sweet72
Sweet72's Avatar
Re: alternator question 2
I believe the 10 and 12 are physically the same as far as fitment. The 12 has more efficient cooling fan. 10 ga. wire should be sufficient. The 12si isn't a one wire alt. but it is internally regulated. Check this link. http://www.madelectrical.com/electri...elcoremy.shtml
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 02-19-2006, 10:41 PM   #3
NitroMike
Active Member
NitroMike's Avatar
Ditto,
All the answers are at "Mad Electric". The owner is great and extremely helpful.
The older I get, the faster I was!!
NitroMike is offline   Reply With Quote
