Old 02-19-2006, 10:42 PM   #1
Green Machine
Green Machine's Avatar
Stronger SBC motor mounts ???
When we put the engine back in the 70, Is there a stronger mount than just the rubber biscut thing ?? I have seen plenty of them in two pieces, and if you get on the gas the fan jumps up and breaks the shroud. This is expensive and unsafe also. Didn't GM make an interlocking type because they were so unsafe or was that just for the cars ??? If I could find a better one for just the left side that would be OK. Guess I could run a bolt and washer clear through ???
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 02-19-2006, 10:46 PM   #2
matthufham
Re: Stronger SBC motor mounts ???
i'm using 73-87 small block mounts. there's a faq on this site about them, it makes engine swaps easy with just 1 bolt to pull on each side, and they're bigger and stronger, and they bolt right in! however if you have 67-72 power steering, you would need a way to bolt on your pump without using the engine mount for the bracket.
matthufham is offline   Reply With Quote
Old 02-19-2006, 10:48 PM   #3
You can easily adapt the later style 73 and up style mounts. Although still rubber, the hold up WAY better that this era's mounts do. I have seen folks use solid mounts on drag cars, but that is a LOT of pressure on the frame structure. I think you need the flex in there. I don't know if they have them for our year mounts, but I have seem some poly mounts for the later style.
Old 02-19-2006, 10:50 PM   #4
68Stepbed
68Stepbed's Avatar
Performance Online sells engine stands that accept the newer style engine mounts.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-20-2006, 07:59 AM   #5
Bowtie67
Bowtie67's Avatar
You can also get poly mounts, and add a chain if you have that much tourque to the left side of the motor cyclinder head to the frame, dont crank it down just leave it so that there is just barely any tension on it.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 02-21-2006, 02:41 AM   #6
4x4Poet
I'm not sure, but I think Energy Suspension makes poly mounts for the 67-72 2wds but not the SBC 4x4s. I know they don't for '71 SBC 4x4s because I researched that one and even asked a local accessories shop that sell ES stuff. No such polymal.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-21-2006, 04:03 AM   #7
Richard
The single bolt style that fits the 4x4 is available through Brothers in poly. They call them big block mounts. Bolt right in on a 72 SB 4x4, I would think that the 71 has the same mounts. Check with the other venders first though. A few of them sell Brothers parts and you will get them for less $$$.
Here they are http://www.brothersonlinestore.com/p...number=BBMM2UR
Richard
Old 02-21-2006, 10:39 PM   #8
Green Machine
Those look much better than the stockers, I'll add it to the list, and the list gets longer...... like always
Old 02-21-2006, 11:39 PM   #9
john@thepier
john@thepier's Avatar
I looked into this just a few weeks back and came up with urethane mounts with a built in safety. So even if they fail, the motor will not come away from the tower. Prothane is the name of the co. I got mine through a place called Suspension Resoration.
john@thepier is offline   Reply With Quote
Old 02-22-2006, 12:00 AM   #10
cdowns
cdowns's Avatar
back in the day gm actually had a retrofit for a torque strap to limit engine movement// i've always used 3/8 stainless cable with a turnbuckle to prevent torque twist
Old 02-22-2006, 09:27 AM   #11
Bowtie67
Bowtie67's Avatar
I cant even think of how many times I have done this as well, cables, chains, turn buckles anything back then because motor mounts where nortoriuos (think I spelled that right) for breaking..
2009 Toyota Tundra
