Old 02-19-2006, 10:50 PM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
What did you get done?
I was off this weekend so I managed to get a few things done. I went Saturday morning and got maintenance work done on my wife's Denali. First stop was Jiffy Lube, then I filled it with gas and took it to Tire & Wheel Connection to have the tires rotated and balanced. While they were at it I had them fix the slow leak in one tire. Turns out it had a 2" long piece of a 1/4x20 bolt in it.
Then I got a phone call from my buddy Keith. He put my Ramjet on the phone and let me listen to it. It has a really nice rumble to it. Man I can't wait to go to Rockwall test it out.
The rest of the afternoon was spent working in my garage with my daughter. We are building a mouse trap car for her 8th grade IPC class. I'll get some pics as soon as I get it together.
Today we worked on the Mouse Trap car again then we went to volleyball practice.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-19-2006, 10:54 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: What did you get done?
Picked up some more parts for the 3/4 ton. Still working on installing a fuel pump and timing chain.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-19-2006, 11:20 PM   #3
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
I stripped down my doors, took out the vent windows and all mechanisms, started taking units down to bare metal, at the same time I filled in the fender emblems on my nos fenders, then found a few low spots on my cab and laid on a thin coat of putty so I can clean the cab up and get my k2 sprayed on it. ALSO---scored an NOS dash from a guy in Kentucky, black of course. So I will be looking forward to getting that this week. Hopefully I can start looking for a radiator this week, I'm hoping to score an aluminum one!
By the way,,,,I want to thank all for the input on working on their rides and keeping me motivated...it's been rough!
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 02-19-2006, 11:21 PM   #4
82c10
needin' money
well tuesday got my term paper typed, while i was typin it, my brother called, he had just gotten engaged, took the old motor to almost a bare block, the crank was turned .020, i am just gonna get it polished, the block was bored .060 it has clean cylinder walls, it apparently had a recent rebuild, it has dish pistons and 462624 heads, so it had a whopping 8.08:1 compression ratio, , unbolted and took the driveshaft out, thinkin about pullin the old tranny out, and maybe this week if it gets a little hotter clean out the interior(its around 10 degrees), can't remember anymore
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 02-20-2006, 12:00 AM   #5
bagged74
its just $$$$$
bagged74's Avatar
cleaned my fish tank and tried to stay warm.
I tried to change the fan clutch on the wifes trailblazer, but failed miserably.
bagged74 is offline   Reply With Quote
Old 02-20-2006, 12:11 AM   #6
Billla
Billla's Avatar
I got my fenderwells and bumper etched, a final coat of DPLF on the core support and the outside of the fenderwells DPLF'd. I'm going to put white DPLF on the bumper, and if I can get the inside of the fenderwells primed this week I'm in good shape!
Pictures at:
http://www.cardomain.com/ride/2206636/3
Billla is offline   Reply With Quote
Old 02-20-2006, 12:24 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
I was just browsing your site Bill. Your doing a great job of keeping your BLOG up to date. Thanks for filling us in...
Articles-
"Refining Sierra"
Old 02-20-2006, 02:28 AM   #8
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Wokred like usual and waited for ice storm that never showed up
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 02-20-2006, 09:30 AM   #9
Jonboy
Slots go on anything!
I went to see Robert Earl Keen in concert Friday night. Saturday was spent looking for a new car. I found a couple, should know today. Sunday was too cold to do much of anything, except stay inside and work on my house. I went through all of my stuff getting everything I needed to do my taxes, and the office was closed. At least that stuff is ready.
Tracey, it seems like there was a recall on the Trailblazer fan clutches. You might check that out.
1974 Jimmy- 5.3/4L80e/NP241
Old 02-20-2006, 10:07 AM   #10
Jim85IROC
Jim85IROC's Avatar
Changed the oil on my fiance's Camry on Friday
My GTA had a little issue with leaky t-tops last summer, and as a result, the black bar between the t-tops rotted. I picked up a cheap used one that had a couple small dents, so I spent a little bit of time sanding that down, filling the dents, then hitting it with a little bit of bumper trim paint. I wetsanded it last night, and hopefully tonight I'll have time to polish it to a nice semigloss shine.
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 02-20-2006, 10:08 AM   #11
Izzy
Trucker.
Izzy's Avatar
I was sick as a dog so I didn't do much. I did get my tyc parking lamps and ckresto 9005/9006 pig tails so I can swap out the w/t front end on the hoe.
Izzy is offline   Reply With Quote
Old 02-20-2006, 11:26 AM   #12
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I got my new engine running Monday night. I got pulled over by the police during my test drive because they said my truck matched the description of one seen leaving several burglaries. I have put about 75 miles on it since then with zero problems, so that's good.
I need to finish up some minor stuff like plug wire routing and hooking up my A/C wiring, but it has been too cold and wet. The only thing I managed to get done this week was to change my break-in oil. I was hoping to finish it up this weekend, but the temps were around freezing, with light rain. I guess it will have to wait.
We have had family in town all weekend, so I probably would not have gotten anything done even if we had good weather.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 02-20-2006, 11:28 AM   #13
Ric83
Ric83's Avatar
Stood up in my cousin's wedding Sat. Slept in kind of late Sun. since it has been a while I have not worked a weekend. Just spent the rest of the day Sun. spending some quality time w/ my wife.
BTW - Took my wife to the doctor Tues. Says the baby is just fine. A few more months and I will be a daddy!!
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 02-20-2006, 03:30 PM   #14
86swb
Born a Chevy Man
86swb's Avatar
Nothing-too drarn cold and all the snow we got. Just stayed inside most of the time.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 02-20-2006, 04:42 PM   #15
flyboy
Another weekend trying to decide whether to go crate or rebuild. Not having my truck running is killin' me.
flyboy is offline   Reply With Quote
Old 02-20-2006, 05:54 PM   #16
EJC78
No Life Like Low Life
EJC78's Avatar
This week end I didnt get to work on my truck, I went to Reno with my wife and son. It was my son's first time seeing snow.(he is only 2) We had a blast though. I know that you all remember The Christmas Story when the little kid is all geared up for the snow and he can hardly walk and can't even move his arms. Well that was the way my son was. lol. Oh yeah my brake kit came in will post pics later.
Eric
1978 Chevy Scottsdale
1960 Impala ZZ4
1965 Buick Riviera GS
2011 GMC Sierra Denali
EJC78 is offline   Reply With Quote
Old 02-20-2006, 09:46 PM   #17
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
http://www.gmtrucks.org/phpBB2/viewtopic.php?p=482#482
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 02-21-2006, 01:54 PM   #18
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Hmmm, had a busy and productive weekend for trucks.
Friday afternoon I went and picked up my newly aquired 6.0L LS motor and took it to my brothers shop.
Saturday I started getting all the parts for my "rolling" advertisement together: Dakota Digital setup, Rod Doors interior pieces, Painless wiring harness, Fuel sending unit.... Plus made up an initial list of parts that I need to order for it.
Sunday I started gathering the parts necessary for making the "spare" truck moveable since it will be the new victim. Purchased the 4L80E a friend left for me. Got the 12bolt with 4.10's out of the garage, found the flip kit, mounted some spare wheels on the diff and rolled it out to the frame. Pulled the front clip off the back of the frame and called it a night
Monday I hunted for the U-bolts for the flip all over the place and finally found them. During such time I semi-organized one table in the garage as the were NOT there. After Jamie and I were hunting for them for about 45 minutes a buddy came over and he started to look also and found them within 2 minutes of looking for them.. DUH. Put the rear diff under the frame and ran into interference with the bolt and mounting plate so I needed to fix that (forgot I pulled 2 leafs so bolt was longer ) work on it a while and called it a night.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
