Anybody have any ideas on what could have happened? A couple weeks ago I was replacing the heater controls in my '72. I ended up tearing most of the under dash housings out of the truck to lube cables and re-adjust all the vent doors. I noticed at that time , one of the wires on the back of the fan switch had been hot enough sometime to distort the plug. Everything was working great,,,til tody! I was running the AC with the fan on high, and all of a sudden noticed that "burnt wire " smell. I turned the blower switch off, but too late. Now the blower doesnt work. Any ideas what could cause my meltdown?????
14.1 @ 96MPH
Probably just an old connector / switch, and possibly wiring and/or a motor that's pulling too much current. Just replace the switch and the socket for now (it's not hard at all) and if it toasts again, look into a new motor and/or rewiring.
Project1970 - LS1 Swap Complete! ![]() |
![]() Join Date: Apr 2002
A couple weeks ago I had a similar problem, but I was blowing my heater fuse. My diode ends on the compressor clutch connector were squeezed together. I guess the blower motor and A/C switch are all on the same circuit. Just something else you can check.
'69 Chev Cust/10 swb, 350/700R4, 5"/6" '70 Chev C10 swb, 67 front, 454/700r4, 4"/5" '73 Chev stepper, 350/3 spd '84 Chev K20 350/4 spd '91 GMC 1500 Suburban 4x4, 350/700R4 |
