brake booster
Has anybody ever done away with the power brake booster bracket & mounted the booster directly to the firewall ?
Can this be done? It hangs way out in the engine bay on my 67,swapping from sbc to bbc later this year, vlv covers almost rub it,,,thought about shortening the brake pushrod arm? TraderJon |
![]() Join Date: Feb 2004
Re: brake booster
yes, in various ways -- here are a few links --the last link is for a 79 booster --link is broke
http://67-72chevytrucks.com/vboard/s...d.php?t=183125 http://67-72chevytrucks.com/vboard/s...d.php?t=175714 http://67-72chevytrucks.com/vboard/s...d.php?t=165344 To use the oem pedal rod hole the booster rod is 8.5" to the center of the rod hole from the firewall mount. Make adjustable if possible. You will lose about an inch of pedal travel -- before same braking-- brakes the same otherwise. Last edited by dennislbrooks; 02-20-2006 at 05:26 PM. |
Re: brake booster
Thanks Dennis
Good info,,,,,Wouldnt you know i just had a 81 truck hauled off after i took all the parts i needed,,,it had hydro boost on it . Thanks JFD |
